Old 06-01-2008, 07:49 PM   #1
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
40% reduced fuel consumption and fewer emissions?
check it out...
six stroke engine...thats right, I said SIX STROKE engine
utilizing the 5/6 strokes with steam to cool the comb chamber
http://en.wikipedia.org/wiki/Crower_six_stroke
http://www.autoweek.com/apps/pbcs.dl...THISWEEKSISSUE
http://peswiki.com/index.php/Directory:Crower's_Six-Stroke_Engine
http://www.popsci.com/node/9649
http://www.damninteresting.com/?p=467
http://www.newindpress.com/NewsItems...hapuram&Page=O
http://www.ultimatecarpage.com/forum...e-engines.html
http://quasiturbine.promci.qc.ca/QTM...Stroke0509.pdf
I piss excellence
and fart awesomeness
Old 06-01-2008, 10:53 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
So the heat-exchange-and-"remove" stroke is also a power-stroke due to the water becoming steam? Huh, well I'll be a Hyundai enthusiast...
That's Nuts. And insane!
I'll be very interested in hearing about the power/fuel economy gains over a similarly-sized deisel or gas engine. Dang.....
Old 06-01-2008, 11:04 PM   #3
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Just when you though that there weren't any significant changes that could be made to the infernal combustion engine.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-15-2009, 08:02 PM   #4
CamaroSpike23
Truth Enforcer
bump
I piss excellence
Old 07-15-2009, 09:27 PM   #5
coolman
Guest
So, now were going to carry a water tank and a gas tank. Love to see how that's going to work in the winter. How will carring 200lb of water on top of fuel save anything. Well, I guess anything is possible. With out guys like that where would we be today.
coolman is offline   Reply With Quote
Old 07-15-2009, 09:31 PM   #6
Mr. Wyndham
bump
Way to necro-post!!
More than a year!
Originally Posted by coolman View Post
so now were going to carry a water tank and a gas tank. Love to see how that's going to work in the winter. How will carring 200lb of water on top of fuel save anything.
Did you read how the engine works?
As for water in the winter...I'm sure they said the same thing about the radiator when that was introduced. What you say is surely a challenge to overcome...if anybody's serious about this thing -- they'll figure it out!
EDIT: Maybe a heat coil in the water tank?
Old 07-15-2009, 10:10 PM   #7
CamaroSpike23
Truth Enforcer
how do you keep your radiator and overflow tank from freezing in the winter time? do you know there are fluids out there that have near identical properties to water, but their boiling and freezing points are extremely different.
Way to necro-post!!
More than a year!
I do what I can. lol
or a heating blanket around the water tank.
either way, that is a small problem to overcome.
I piss excellence
Old 07-15-2009, 10:13 PM   #8
coolman
Guest
If your talking about antifreeze, that wouldn't do very well in a combustion chamber, plus think of the enviromental impact.
Old 07-15-2009, 11:09 PM   #9
CamaroSpike23
Truth Enforcer
I could care less about the environmental impact. but you could easily run methanol/water mix just fine in there
I piss excellence
Old 07-15-2009, 11:28 PM   #10
coolman
Guest
Methanol burns and it's boing point is alot lower then water 148deg f.
This is the shit they run in race cars. I don't think the inventer intended to blow up his invention. I'm a 25 year refrigeration man, I know all about the boiling points of fluids. I'm going to stop feeding the troll now.
Old 07-16-2009, 12:09 AM   #11
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
ummmm... what troll?
Old 07-16-2009, 01:18 AM   #12
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
hrmmmm?
Nice necro spike.
Old 07-16-2009, 03:07 AM   #13
manimsoblack
manimsoblack's Avatar
Look at his post count and yours and re-evaluate that statement. Just because he may not know as much about a particular thing than you do doesn't make him a troll. The exchange of ideas is the point of forums, try contributing.
[/soapbox]
I think that's a cool deal. When not have it run on just gas during the heating period and have a separate section that turns on once optimal temperature is reached. Also I'm sure chemists out there can come up with some crazy liquid that'll serve that purpose.
Old 07-16-2009, 09:41 AM   #14
CamaroSpike23
Truth Enforcer
I'm fully aware that methanol burns. its been used in more than race cars. on top of its burning properties, it also cools an air intake charge. or have you never heard of methanol injection? commonly used in boosted applications and even in some N/A applications (that arent full blown race cars). part of the diesel and otto process involves blowing up fuel and air... or did you forget the basics of internal combustion engines?
boiling point isnt the topic of the discussion, the freezing point is.
or did you mean something else by this comment?
and the "200lbs of water" is a far stretch.
the amount of water needed to be sprayed into the comb chamber to cool it down is not much. granted, if you are on a 2000mile cruise accross the country, then yes, you will be refilling about every other fuel stop.
and the troll comment. thats just funny.
hrmmmm?
Nice necro spike.
thanks. its a worthy topic of discussion as its a new look on things, tho some people just cant get their minds out of their own heads to look at all aspects before criticizing.
[/soapbox]
its not just the post count... its also the time I've been here... and the date I originally posted the thread.
and the setup is designed so that the water isnt even injected till the engine reaches 400*F which is around 200* C.
I piss excellence
Americans unwilling to pay for big fuel economy gains, carmakers say Scotsman General Automotive + Other Cars Discussion 7 04-18-2008 01:27 PM
Less Fuel and More Safety TAG UR IT General Automotive + Other Cars Discussion 2 10-14-2007 01:12 PM
