Old 10-09-2008, 08:40 AM   #1
SSmoked
SSmoked's Avatar
Drives: '12 Camaro ZL1 #1255
hexegon over our north pole??
k guys i came over this on another forum. can somone into this sci-fi stuff explain it to me
[quote name='Murray' date='Oct 4 2008, 01:10 PM' post='916241']
Okay, we discovered this last night and so many people are just writing it off as a satellite glitch. Cool. Everyone's entitled to their opinions, that's fine.
But I think it's important everyone just sees this and takes it into consideration.
http://showmescifi.com/2007/03/27/saturns-...red-by-cassini/
Earth (I JUST took this):
Saturn:
Open up google earth for yourself, turn on the cloud layer. Compare it to environment canada weather radar to prove that it's current cloud coverage.
Now why does it not go away?
I even took the time to measure the angle on said wierd shape, and it's 60 degrees, the exterior angle of a hexagon:
http://www.ul.ie/~cahird/polyhedronmode/hexagon.htm
What do I think this is? I have no f**king clue. All I know is it's there.. and it's STILL there.
If you're with me on this, click here and/or here, otherwise, pretend you didn't read this and save me the headache of argument.
I think this is the thread where everyone starts to label me as crazy. BRING IT.
[/quote]
k i didnt post this so dont bring the hate on me.
discuss
SSmoked is offline   Reply With Quote
Old 10-09-2008, 09:32 AM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
its what happens when they stitch the satelite photos together. nothing more nothing less..
headpunter is offline   Reply With Quote
Old 10-09-2008, 09:35 AM   #3
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
exactly.. photos (even satelite ones) are flat... in that type of modeler you are applying them to a sphere.. and they need to be stitched together some how. Its easier to take one shot directly above the north pole and then 'banana' them together.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 10-09-2008, 09:37 AM   #4
headpunter
headpunter's Avatar
Drives: Man
also that first pic of earth is a rendering not an actual picture
Old 10-09-2008, 09:55 AM   #5
The_Blur
Moderator
The_Blur's Avatar
Google does a really good job of bringing the Earth to consumers with maps and directions. Google, however, is not 100% correct. That's all this shows.
warn 145:159 ban
Old 10-09-2008, 10:48 AM   #6
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
There is a mothership above the north pole. It is cloaked so there is some distortion that appears to be a 6 sided geometric pattern. Now that we know this, they will invade in 25 Gwemf days. I don't know how long that is in earth days.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-09-2008, 10:59 AM   #7
The_Blur
Moderator
The_Blur's Avatar
We're doomed!
warn 145:159 ban
Old 10-09-2008, 11:15 AM   #8
headpunter
headpunter's Avatar
Drives: Man
how did your learn what a gwemf day was. that information is above top secret classified.
are on the way and they arent from GM.....
Old 10-09-2008, 11:24 AM   #9
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
It's a Man-Bear-Pig portal, EVERYONE RUN!
Kyle2k is offline   Reply With Quote
Old 10-09-2008, 11:28 AM   #10
SSmoked
SSmoked's Avatar
i figured i would ask the more mature members that know more about computer and satiliets and stuff. thanks guys.
not sure if u guys checked the links that were included in the quote too. the blue beam plan. sounds a little crazy if u ask me.
Old 10-09-2008, 11:43 AM   #11
lalometalik
killer bAnana
lalometalik's Avatar
Drives: 1985 z28
i may have been of some help if it was a pentagon
but my guess is that its a time/space portal that leads to a room with a moose!
"Shut your noise tube, Taco Human!"
lalometalik is offline   Reply With Quote
Old 10-09-2008, 12:00 PM   #12
scotchsride09
It's STARSCREAM!!!
scotchsride09's Avatar
Drives: 2003 Nissan Frontier S/C DR
Well the pictures of Saturn are more compelling to me than any of the Earth pictures; simply because I've seen pictures of the North pole before that aren't so dramatically cut. However, from a more scientific perspective; I suppose it's possible that the Coriolis effect and jet stream patterns could at some point cause the visible atmosphere at the pole of a planet to resemble a hexagon. The Coriolis effect is long and complicated to explain accurately, if you really want to understand it (if you don't already) Wikipedia has a good long article on it: http://en.wikipedia.org/wiki/Corioli...in_meteorology .
But the basic gist of it is that all fluid things in the Northern hemisphere will turn to the right relative to its source (ocean currents, winds, pressure systems). All fluid things in the Southern Hemisphere will turn to the left, assuming you are looking at a side view of the Earth as represented on a flat surface. If you switch that view to looking directly onto the North pole; the pressure system closest to the pole turns into a small circle and circles the pole because of the Coriolis Effect. But because of the rest of the systems pushing on it from the lower latitudes, and turning into it, I imagine at some point it's possible they could all be pushing on it in such a way to make it resemble a hexagon. And I know nothing of the atmosphere on Saturn but perhaps the gases and the pressure systems of the atmosphere are so constructed that they allow for a more regular representation of the shape than here on Earth, where because of the convoluted-ness of our pressure systems which change so frequently, it would be more of a coincidence if that image were captured in full.
Kind of a stretch, but it's the only explanation that comes immediately to mind.
Did I mention I have a sense of humor?
Right now it's an '03 Nissan Frontier Supercharged Desert Runner I call Starscream.
On order is a 1SS/ RS IBM with Black Rally Stripes, Beige Interior, manual transmission and a sunroof! Oh, and a stereo upgrade too! Ordered from CamaroScotty in WI. How will I get my baby home?
scotchsride09 is offline   Reply With Quote
Old 10-09-2008, 04:17 PM   #13
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
the magnetic pole is shifting at 60* intervals.....
2012 doomsday prophecy will be revealed!!!!!
I want my Z28 Camaro NOW.... before its too late!!!!!
I piss excellence
and fart awesomeness
Old 10-09-2008, 06:43 PM   #14
ucla1ove3
Drives: soon to be 2010 CAMARO :]
yea we are all gonna die like the aztecs guessed lol. 2011 or 2012 was it i forget lol.
ucla1ove3 is offline   Reply With Quote
VIDEO: Yellow Camaro unveiling at North Hollywood design studios Tran Camaro Photos | Spyshots | Video | Media Gallery 34 07-31-2008 02:52 AM
North Carolina Fbody fans boxmonkeyracing Off-topic Discussions 0 01-31-2007 03:40 PM
