10-05-2020, 07:45 AM | #1 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
LT2 Manifold & 95mm TB
Installing the LT2 intake manifold & 95mm LT5 TB this week. No tune yet but will be getting one down the road.
What do you guys think the HP gains on this install? I will only be porting the opening around the TB so everything lines up. (Intake, adapter plate, TB) I also order the corvette engine cover and will take the plate off that says Corvette. Will have to mode that plate somehow to get a decal/emblem with Camaro. I chose this cover because it has a stainless steel plate with Corvette on it and can be taken out to mode it. Maybe flip it over and change sides depending what it looks like on the other side. Wrap it and a decal possibly. Stay tuned.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
10-05-2020, 08:23 AM | #2 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
Got Mine From GPI on Sunday, now the sanding cutting and shaving begins. Now how to fill the 4 holes on top?
Thanks GPI super fast shipping!
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake Last edited by OB0001; 10-05-2020 at 07:26 PM. |
10-05-2020, 12:14 PM | #3 |
Man I wish I could make one fit on my C7, but just too tall for the Cowl.
10-05-2020, 07:04 PM | #4 |
Drives: 2020 ss Join Date: Nov 2019
I used epoxy and body filler. Might try one with some plastic welding next.
2020 Camaro SS
Heads,cam,hi-ram,hhp tcm |
10-06-2020, 04:05 PM | #5 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
10-06-2020, 07:57 PM | #6 | |
Good info on below link on porting the throat https://youtu.be/rZSprqJHA9I
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 10-07-2020 at 05:55 AM. |
10-07-2020, 10:57 AM | #7 |
If you take the porting back in the throat I’d say a solid 20-25rw..2mph+
Anyone using the insulator pad under the manifold?
10-07-2020, 11:52 AM | #8 |
I am pretty sure the insulator pad is just to help reduce engine noise and no other purpose. I am not putting it back on. Weight savings!!!! Lol
10-07-2020, 08:43 PM | #9 |
Well I ported the LT2 today. Rock Auto just delivered the 95mm and Katech Adapter is also here. I will do some more hand sanding tomorrow to smooth out some nicks the dermal caused. Over all I am pumped to put it on and hopefully I am impressed with the manifold and TB. I lined it up in the throat of the manifold and I shaved off enough for the 95mm to flow with no lip from the manifold.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 10-07-2020 at 08:55 PM. |
10-07-2020, 09:05 PM | #10 | |
Drives: 2018 Camaro SS Join Date: May 2019
Really feels night and day different. Haven't tracked it yet but was running 8.0 1/8 mile before and hoping to be mid 7's now. I think you gonna be impressed with the results ! |
10-07-2020, 09:13 PM | #11 | |
10-08-2020, 11:26 AM | #12 |
It’s in!!!!!!
You have to knock those bolts lose. Thanks to GPI for aligning the bottom and putting the rear connector on, the map extension made this an easy install. Time to clean the tools and organize the garage before a drive. The idle was fine, the sound with a slight rev was different. Could be a combination of the muffler pad not on any more and of course the bigger manifold/TB. The paper gasket at the rear sealed nicely. After drive will double check bolts, now just have to wait for the corvette engine cover which will be moded for a Camaro emblem or wait for a company to produce a sticker. Hmmmmm, now I have a strut tower for sale. Lol
10-08-2020, 12:12 PM | #13 |
Drives: 2019 Camaro 2SS Vert Join Date: Apr 2020
is the strut tower no where near close to fitting back on? or with some slight dremelling to the upper intake would it fit?
10-08-2020, 02:05 PM | #14 |
Not sure, waiting for me engine cover so I am probably not going to put it back on. I had thought of washers or spacers to raise it up from strut tower with longer bolts. I will test fit it for you later if your just wondering if it fits. Some other guy took a chunk out of the centre to make it fit but that really didn’t look so good.
