Old 03-15-2008, 08:36 AM   #1
LSxcellent
Drives: MINI Cooper S
Pontiac G8 GXP has been REVEALED!!!
I just can't F-ing believe they ACTUALLY released it! It's like a dream come true! Words. They fail me.
http://jalopnik.com/367820/2009-pont...l-transmission
Unbelievable!!!
"PONTIAC ANNOUNCES THE 2009 G8 GXP
High-Performance Flagship Combines Progressive Design and Powerful Performance
NEW YORK - Today Pontiac announced the flagship of its GXP performance series, the G8 GXP high-performance sedan, at the New York Auto Show. This 2009 model will join the Solstice, G6 and Torrent GXP models in Pontiac dealerships in late 2008. The G8 GXP takes the G8's responsive driving experience, refined passenger environment and aggressive good looks to a new level. It also delivers an enjoyable driving experience, thanks to a 6.2L V-8 that produces in excess of 400 horsepower.
"More than just raw power, the GXP delivers the sophisticated yet exciting driving experience that enthusiasts expect in a car costing far more than the GXP," said Jim Bunnell, Buick-Pontiac-GMC general manager
Engine performance
The heart of the G8 GXP is the 6.2L LS3 small-block V-8, currently rated at 402 horsepower (300 kW)* and 402 lb.-ft. of torque (546 Nm)* pending final SAE certification. This engine is the newest member of GM's small-block V-8 family. It features a revised, larger-bore cylinder block, high-flow, L92-style cylinder heads; larger-diameter pistons; unique camshaft and camshaft timing; revised valvetrain with offset intake rocker arms; high-flow intake manifold; and high-flow fuel injectors.
The LS3 engine has an aluminum cylinder block with cast-in-place iron cylinder liners. Larger bores help create a 376-cubic-inch displacement. The block casting also features revisions and machining in the bulkheads to enhance its strength and improve bay-to-bay breathing. New pistons were designed for high-rpm performance.
New, high-flow cylinder heads aid engine breathing and are based on the large port and valve design found on the LS7 engine and other GM L76 engines. The larger-capacity, straighter intake port-design optimizes intake flow to the combustion chamber, an effect augmented by large valves, measuring 2.16 inches (55.0 mm) on the intake side and 1.59 inches (40.4 mm) on the exhaust side.
Pending final testing, the G8 GXP is expected to deliver 0-to-60 mph performance of about 4.7 seconds, and a quarter-mile time of 13.0 seconds at 108 mph.
Six on the floor
A new six-speed Tremec TR6060 manual transmission is optional on the G8 GXP. This next-generation manual smoothly transfers the engine's power and torque to the rear wheels with a reduction in shift throw. The transmission features a host of refinements including premium gear synchronizers; stronger gears, housing, and bell housing; a single-piece counter shaft; and machined gear teeth.
The standard Hydra-Matic six-speed 6L80 automatic transmission is technologically advanced and robust. It uses a clutch-to-clutch operation and an integrated 32-bit transmission controller to deliver smooth and precise shifts. The six-speed has a generous 6.04:1 overall ratio that enables a "steep" first-gear. The result is strong launch acceleration along with "tall" overdrive ratios that lower engine rpms for better fuel economy and reduced noise.
A 3.27 final drive ratio comes with automatic-equipped GXPs, and a 3.70 gear is matched with the manual transmission. A limited-slip differential is standard.
High-performance suspension
The G8 GXP rides on the G8's 114.8-inch (2915 mm) wheelbase with wide front ( 62.7 inches / 1,592 mm) and rear ( 63.3 inches / 1,608 mm) tracks. The four-wheel independent suspension is fully adjustable and is tuned for the highest performance in the G8 family. The GXP's ride and handling was developed and validated on racetracks and highways around the world, including the famed Nürburgring racing circuit. It rewards the driver with sharp, immediate responses, as well as a well-balanced road feel during spirited driving.
The suspension employs a MacPherson strut design in the front and a four-link, coil-over-shock design in the rear. A direct-acting front stabilizer bar, decoupled rear stabilizer bar and lateral ball joints on the rear suspension deliver increased lateral stiffness for more responsive handling. The front suspension features fully adjustable caster, camber and toe; the rear suspension has fully adjustable camber and toe, for more precise tuning.
Steering and brakes
The steering rate for the GXP is tuned to provide immediate response with definitive driver feedback. Like the G8 sedan and GT, the GXP's steering box is located ahead of the front axle line for a quicker, more direct feel.
The Brembo braking system matches the GXP's boost in performance with an equivalent increase in stopping power. The system includes 14-inch (355 mm) vented front and 12.76-inch (324 mm) rear disc rotors, with special quad-piston alloy calipers in front. The alloy calipers on the rear brakes have single-piston actuation. The four-wheel disc brake system includes standard anti-lock brakes and traction control.
Wheels and tires
The GXP rides on 19-inch polished aluminum wheels with a special machined face. Performance-oriented summer P245/40R19 tires are standard, and a comparable all-season tire is available. Combined with the suspension and steering enhancements, this setup gives the GXP exceptional cornering grip.
Exterior styling
The G8 GXP exhibits strong Pontiac design cues. A unique front fascia with a lower splitter and a distinctive rear fascia diffuser contribute to its sporty look. The dual-port grille, fog lamps, bold wheels and confident, wheels-at-the-corners stance are all unmistakably Pontiac traits.
Interior amenities and comfort
The G8 GXP's interior is driver-oriented with aesthetic and tactile details like instruments with a sporty appearance that match the car's performance. Interior materials consist of satin and chrome trim and high-quality textured materials throughout. The instrument cluster glows with crisp, white light on the primary instruments. Pontiac's signature red lighting illuminates the rest of the instrument panel cluster.
Standard comfort and convenience amenities include:
* Highly bolstered two-tone sport seats with color-coordinated gauge cluster and GXP embroidery
* Leather-trimmed steering wheel and gear shifter
* Power-adjustable front seats
* Fog lamps
* Alloy sport pedals
* A 230-watt Blaupunkt audio system
* XM Satellite Radio
The seats offer firm support to hold occupants in place during aggressive cornering. The standard heated leather seats were designed to deliver excellent comfort during long drives. They are available in Ebony or an Ebony/Red two-tone.
Safety
Maintaining the G8's tradition of a full suite of standard safety features, the G8 GXP includes:
* Four-wheel disc brakes with ABS and traction control
* Electronic stability control
* Seat-mounted thorax air bags and dual-stage frontal air bags for front passengers, with automatic passenger sensing system
* Roof rail side-impact air bags for both seating rows
* OnStar
~LSX
"When you turn your car on, does it return the favor?"
LSxcellent is offline   Reply With Quote
Old 03-15-2008, 09:52 AM   #2
z28camaro2471
C5 Member #227
z28camaro2471's Avatar
Drives: Camaros
That's awesome. I wonder how much of this will make it into the Camaro? Sounds like the performance numbers match up with Ed's statement.
z28camaro2471 is offline   Reply With Quote
Old 03-15-2008, 09:52 AM   #3
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Detuned LS3, but it should be more than enough to lay a whoopin on the competetion.
Also, its a hair above 400 hp . . . wonder if its got AFM
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 03-15-2008, 09:58 AM   #4
smokn'
Drives: Banana boat
the goats been reborn!!!...with 2 extra doors!!!! and .2 extra liters!!! lol sorry, i love goats. so i guess this officially(as if we didn't already know) dismisses any idea that the GTO name is ever coming back. i guess it's good, the GTO was really a place holder while the camaro was on vacation. oh well, i love the goats anyways. sweet lookn' G8
smokn' is offline   Reply With Quote
Old 03-15-2008, 11:07 AM   #5
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
D@mn ...could you imagine? Room for 4 AND an LS3??? That is pretty darn cool.
Somthing else to think about...Blaupunkt stereo..maybe in the works for the Camaro?
Old 03-15-2008, 11:28 AM   #6
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Poor man's CTS V???
I'm likeing the GTO \ G8 more and more.
Old 03-15-2008, 12:48 PM   #7
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
put me down for one in the 2010 model year, please
got tequila?
SilverTurtle is offline   Reply With Quote
Old 03-15-2008, 01:50 PM   #8
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
Maybe the Camaro will get a Blauplunkt, but it also could just be a Pontiac feature. Pretty darn impressive for under $40K, and it ought to trump the Charger SRT8 right nicely. 6 speed manual option is good. I hope it makes its way down to lesser models as well. The styling additions are pretty restrained. That's surprising.
stovt001 is offline   Reply With Quote
Old 03-15-2008, 01:51 PM   #9
Scotsman
Auto Pilot
Scotsman's Avatar
Drives: Gunmetal
Family hauler of choice right here.
"Let the rest of the world dream of Ferraris, Lamborghinis and dinky little British two-seaters. In this country speed doesn't look like that." Got SS?
Scotsman is offline   Reply With Quote
Old 03-15-2008, 02:16 PM   #10
Dave McFly
*new car smell*
Dave McFly's Avatar
Drives: 2007 Ford Mustang 'Natasha'
Send a message via ICQ to Dave McFly Send a message via AIM to Dave McFly Send a message via MSN to Dave McFly Send a message via Yahoo to Dave McFly Send a message via Skype™ to Dave McFly
Talking
but i thought the LS3 had like 430 hp? i am sorry but the extra money this car is going to cost over the GT model for like 40 hp is just not worth it to me. I would take GT and ad parts to bump it up to the 400 mark instead.
"May the forces of evil become confused on the way to your house."
George Carlin
Dave McFly is offline   Reply With Quote
Old 03-15-2008, 02:18 PM   #11
SilverTurtle
Originally Posted by stovt001 View Post
Maybe the Camaro will get a Blauplunkt, but it also could just be a Pontiac feature... The styling additions are pretty restrained. That's surprising.
I'm tending to believe that since the GTO got the Blaupunkt stereo when it was in production, this is a Poncho option... I'd rather it be that way, because I'm not a huge Blaupunkt fan... I'd rather see a Delco/BOSE setup in the Camaro.
and I am stoked about this car because to me it just screams "sleeper"... debadge that baby and you'll be killing Mustangs and Challengers with your "V6" looking G8
got tequila?
Old 03-15-2008, 04:23 PM   #12
stovt001
stovt001's Avatar
Don't forget the transmission and suspension upgrades too.
Old 03-15-2008, 05:41 PM   #13
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Detuned... Yeah like the LS1 in the "Forth Gen"
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 03-15-2008, 06:02 PM   #14
NOODLESgoneWILD
IS IT 2009 YET???
NOODLESgoneWILD's Avatar
Drives: '05 Z51 Black Vette & '06 H2
Send a message via MSN to NOODLESgoneWILD
I have a question??????
I haven't been keeping current on all the Pontiac production lines (and im to lazy to do my own research)...so forgive me for my ignorance.
But is the G8 the replacement for the Grandprix? or is it a new production line?
NOODLESgoneWILD is offline   Reply With Quote
Chevy, not Pontiac to Get Small RWD sedan? stovt001 General Automotive + Other Cars Discussion 7 12-07-2007 03:47 PM
Pontiac 350 Motor-Fully Assembled dveigel General Automotive + Other Cars Discussion 2 11-12-2007 01:27 PM
Future Pontiac Solstice Variations stovt001 General Automotive + Other Cars Discussion 24 11-09-2007 08:53 PM
2008 Pontiac G8 review in Car and Driver Fbodybuddy General Automotive + Other Cars Discussion 9 10-26-2007 11:13 AM
Edmunds.com review of Holden Commodore... good info. LSxcellent General Automotive + Other Cars Discussion 6 07-23-2007 06:49 PM
