Old 07-11-2012, 12:56 PM   #1
Chris@Livernois
Chris@Livernois's Avatar
Drives: 2010 Camaro
Livernois/RHS 429ci Stroker for 2006 CTS-V
An out of state customer sent his 2006 CTS-V to us for a long list of modifications.
We are currently building the new engine which is based of off an RHS aluminum block. This will be a N/A 429ci build
Parts consist of:
Livernois Forged Steel Stroker Crankshaft
Livernois Exclusive 11:1 compression Forged Pistons w/ Fully Coated Top and Skirts
Livernois Exclusive Rings, Locks, and Wrist Pins
Livernois Spec H-Beam Rods w/ ARP 2000 Bolts
Livernois CNC LSX-LS7 Cylinder Heads
Livernois Stage 2R Max Camshaft
Comp Short Travel Race Hydraulic Roller Lifters
Coated Bearings
ARP Studs
Melling Oil Pump
Here are some photos minus intake and covers
We will also be installing:
Kooks Longtube Headers
Kooks Midpipe w/ Cats
Corsa Exhaust
CAI
LS9 Clutch
Aluminum Flywheel
Shifter
Coil Overs
Sway Bars
Toe Rods
Trailing Arms
9" Differential
35-Spline Axles
Thanks for looking!
Regards,
Rick LeBlanc
Livernois Motorsports
Chris@Livernois is offline   Reply With Quote
Old 07-11-2012, 03:39 PM   #2
LOWDOWN
Downright Upright
Drives: Daily
Specs:
Bore, Stroke, anticipated 91-octane rwhp (or is this build for race gas only)?
With a 9" transplant, this application is for strip use, I presume.
LOWDOWN is offline   Reply With Quote
Old 07-11-2012, 03:49 PM   #3
wow, can I have that engine for my SS
Old 07-12-2012, 09:55 AM   #4
Chris@Livernois
Drives: 2010 Camaro
Thanks for the replies!
Originally Posted by LOWDOWN View Post
Specs:
4.125" Bore, 4.000" Stroke and it will be tuned for 93 octane pump gas.
I'm not sure what kind of power numbers to expect. He's not using a very aggressive camshaft. Specs are 235/242 .603/.618 114 LSA.
We have several C6Z N/A stock bottom end head/cam, bolt-on builds that make 600-630 RWHP with our stage 3 camshaft, but it's more aggressive than he wants in this car.
-Rick
Old 07-25-2012, 11:58 PM   #5
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
bump
any news?
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 07-26-2012, 01:00 AM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
will it be powerful?
mikeSS is offline   Reply With Quote
Old 07-26-2012, 02:00 AM   #7
S3XPanther
by Odeon
S3XPanther's Avatar
Lol.
Will it have balls?
Old 07-26-2012, 06:50 AM   #8
S3XPanther
by Odeon
S3XPanther's Avatar
Also, is the tranny otherwise stock?
Old 07-26-2012, 12:43 PM   #9
Chris@Livernois
Drives: 2010 Camaro
Originally Posted by S3XPanther View Post
bump
any news?
The engine is complete, waiting on other parts to complete the build before we tear into it.
This is the car
It should make good power, but that was not the only goal the customer had. He wants something that will be durable and can be used as a daily driver. He's not using a very aggressive camshaft. Specs are 235/242 .603/.618 114 LSA.
We have several 472ci N/A stock bottom end LS7's with head/cam, bolt-on builds that make 600-630 RWHP with our stage 3 camshaft, but it's more aggressive than he wants in this car.
-Rick
Old 07-26-2012, 07:12 PM   #10
S3XPanther
by Odeon
S3XPanther's Avatar
This is the car
-Rick
I have the same goals. I want to mate this setup, or one very similar, to my 6L80 and not have to worry about anything for a looooong time. Is he utilizing the stock tranny in his build?
Old 07-27-2012, 05:33 PM   #11
S3XPanther
by Odeon
S3XPanther's Avatar
bump
Old 08-15-2012, 05:30 PM   #12
S3XPanther
by Odeon
S3XPanther's Avatar
bump. Any results?
Old 08-17-2012, 01:27 PM   #13
Chris@Livernois
Drives: 2010 Camaro
bump. Any results?
Still waiting on quite a few parts, so the engine isn't in the car yet. I'll post updates as we progress.
Thank you,
Rick
