Old 04-29-2009, 07:29 PM   #1
War Eagle
War Eagle's Avatar
Drives: 1969 Chevelle, Avanti, 2010 GT500
Next Generation Hummer Engine Cancelled
Here is a picture of the engine GM had planned for the next generation of Hummers before the economy went south and gas prices went up.The towing capacity would have been significantly increased.
Back in a Chevelle after 41 years.
War Eagle is offline   Reply With Quote
Old 04-29-2009, 07:37 PM   #2
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
Black 2SS RS LS3 Inferno Int. '17 1LE replica 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Ideal performance upgraded clutch master cylinder:Tick performance upgraded slave cylinder/throwout bearing: Mantic 9000 twin disk clutch & light weight flywheel: Tuned by Doug Ring at ECS. 475RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 04-29-2009, 08:42 PM   #3
lil_chef
Drives: 2010 Mustang GT
what would that even hook up to......
lil_chef is offline   Reply With Quote
Old 04-29-2009, 08:43 PM   #4
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Ever seen Star Wars and that small moon??
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 04-29-2009, 09:23 PM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I've seen similar engines before...I have no idea why they're built, or what they do besides shock and awe! They've got to be some sort of industrial power plant....
Old 04-29-2009, 09:27 PM   #6
dayvedayve
Drives: 2006 Chevy Avalanche
Ship motor, maybe.
dayvedayve is offline   Reply With Quote
Old 04-29-2009, 09:35 PM   #7
09'Z28
The "Mad Hamster"
09'Z28's Avatar
^ that would be my guess
Old 04-29-2009, 09:41 PM   #8
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
WOW
Old 04-29-2009, 09:43 PM   #9
nester7929
Rice Harvester
nester7929's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Aircraft carrier engine.
nester7929 is offline   Reply With Quote
Old 04-30-2009, 09:15 AM   #10
djsnoflake
Faith Keeper
djsnoflake's Avatar
I thought aircraft carriers ran on nuclear?
Old 04-30-2009, 09:56 AM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Maybe a cruise ship
They should put a big 'old TVS 2300 on there
'20 ZL1 Black "Fury"
Old 04-30-2009, 10:51 AM   #12
MrIcky
MrIcky's Avatar
Drives: Dodge Ram Megacab & Cobalt SS
Is that a turbo housing in the top right corner of the picture? If it is, pfffft- weaksauce- they need MORE CI so they can NA that bitch.
MrIcky is offline   Reply With Quote
Old 04-30-2009, 11:01 AM   #13
The_Blur
Moderator
The_Blur's Avatar
It's not big enough.
warn 145:159 ban
Old 04-30-2009, 11:30 AM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Ship engine most likely. If you're using a diesel generator that size, you might as well go with a boiler/turbine setup. The work platforms and the 102 rpm redline make it unlikely for a gargantuan heavy haul dump truck. So I'd say its for a meduim sized cargo or cruise ship. Engines get a lot bigger than that.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
BMEP-Or why you only need 1 camshaft rayhawk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-03-2008 12:28 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 04:35 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
