05-06-2008, 05:06 PM | #1 | ||
Auto Pilot
Drives: Gunmetal Join Date: Feb 2007
GM moves closer to HCCI engine production
Imagine getting V6 fuel economy from your V8 Camaro. It could happen sooner than later with HCCI engine technology
"Let the rest of the world dream of Ferraris, Lamborghinis and dinky little British two-seaters. In this country speed doesn't look like that." Got SS?
05-06-2008, 05:18 PM | #2 |
Drives: 07' Sunburst Cobalt SS/SC Join Date: May 2008
Hmmm Interesting
05-06-2008, 05:38 PM | #3 |
Petro-sexual
+2; very interesting. You know the bug-eaters are having their way when a gas engine runs like a diesel. J/K
05-06-2008, 11:16 PM | #4 |
Moderator.ca
I wonder how much gas would this system save?
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
05-06-2008, 11:20 PM | #5 |
E.B.A.H.
Drives: you wild... Join Date: Mar 2007
Sounds like diesel technology. Heat up the cylinder and then use compression to combust the fuel. It's a diesel engine that uses gasoline, right?
05-06-2008, 11:34 PM | #6 |
Drives: 2010 Camaro 1LT/RS M6 Join Date: Nov 2007
I think the 305 in my 3rd Gen had this technology. Every time I let someone else drive it, when I got it back it would run after I shut the engine off. That was working at idle for about a minute anyway... if I kept giving it gas I bet it would have done it longer.
05-06-2008, 11:36 PM | #7 |
I used to be Dragoneye...
"or HCCI, which allows petrol cars to improve fuel efficiency by as much as 15%"
The current, non-HCCI, 2.2 in the Cobalt XFE gets 25city/36hwy...so 15 percent increase: 28/40? Plus the DI and the VVT they've included in the Aura's test engine,...I'd say we're looking at an easy 45mpg four-banger. Eat that, Prius!!! |
05-07-2008, 12:15 AM | #8 |
Auto Pilot
05-07-2008, 09:54 AM | #9 | |
Petro-sexual
05-07-2008, 10:27 AM | #10 |
Moderator
I'd love to see this happen. It's technology like this that makes me think GM will overcome new regulations on efficiency. Plus, more efficiency is always good.
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
05-07-2008, 12:53 PM | #11 |
Then you're gonna love me
Drives: 2010 Black Camaro Tumbler RS Join Date: Dec 2007
Interesting, well that puts it back in my mind when it was mentioned early on that the Camaro could have 30 MPG, this sorta development now makes me think maybe it wasn't the 4 cyc that was only suppose to do that kinda mileage. Hmmmm..
Wow if this is in the new Camaro. I'm just losing my mind, is it April 2009 yet?!?!?!?!
Own- "Does it come in Black?" Exterior/ Grey Interior 2LT/RS Automatic
_____________________________________ The Batman would only drive a 2010 Camaro and buy from Camaro Scotty. 'Nuff said. Anyone that knows of a place that is making the Concept Shifter for the new Camaro. (Auto specifically) Please let me know. Order# NDTMVP Ordered 10/23/08. 2000 on 5/21/09... It begins..... 4B00 on 6/26/09... In transit to the Cave 5000 on 7/6/09 it waits for my arrival! 1000000 on 7/10/09 The Tumbler is in the Cave! |
05-07-2008, 01:47 PM | #12 |
Go Rays!
Drives: 03 Trailblazer Join Date: May 2007
Hmm.
There's something I still haven't been able to fathom yet. My '91 vert I had (305 TPI) got 21+ MPG on the highway, and this was 17 years ago in a CONVERTIBLE. My 400+ HP Supra got 25 MPG hwy, and it was a '94. early 90's HOndas could easily get 40 MPG on the highway...so why are these numbers so hard to believe now? I know cars are heavier now (duh, make them lighter and save gas folks!) but there's got to be something else wrong with the picture here that it's so difficult to fathom a V8 making over 25 MPG. |
05-07-2008, 01:49 PM | #13 |
Drives: 2006 Cobalt, 2004 Taurus wagon Join Date: Oct 2007
It mentions the added benefit of not using expensive diesel emissions systems. It also so should mention the benefit of diesel efficiency without diesel prices.
I'd pay a little extra to get this system in my Camaro. |
05-13-2008, 11:49 AM | #14 |
Drives: 1988Nissan Pulsar (meh,beater) Join Date: Nov 2007
Actually, the large arguement for HCCI is the improvement in emissions.
Normally combusted gasoline burns, producing HEAT andthus NOx emissions. HCCI doesn't burn the charge, but actually harnesses the compression energy to combust the entire charge simultaneously. Because it doesn't technically *burn* (like in a diesel) there is actually very little heat produced. They already have these engines running, but only for certain drive cycles. They are working on a way to get them to run under more conditions. Essentially, using computer controlled forced induction and constantly monitoring cylinder temperature, intake charge temperature, and barometric pressure they can calculate how much intake duration (valve control) they need to get the engine to 'knock' at the right time. Differenced between this and diesel... Much lighter block, less torque (no sustained burn). Ignition timing isn't adjustable by adjusting fuel, it's all computer controlled. I don't know if that made any sense, but when I learned about this technology in class I geeked out. I'd be more excited in looking at what kind of POWER you can get out of your V8 than what kind of fuel economy you can get. HCCI engines produce vastly more power than standard combustion because of the energy that isn't lost as heat. However the engine sounds a little different :S |
Similar Threads | ||||
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
Another tidbit about production date and engine lineup...LOOK HERE! | CamaroSpike23 | 5th Gen Camaro SS LS LT General Discussions | 154 | 02-03-2008 03:38 PM |
Axial Vector Engine | Mr. Wyndham | General Automotive + Other Cars Discussion | 6 | 06-20-2007 04:00 PM |
