#1 |
![]() Drives: f150 Join Date: Jan 2010
2012 Boss 302 track test
Vehicle: 2012 Ford Mustang Boss 302 Laguna Seca
Odometer: 2,489 Date: 3/1/11 Driver: Mike Monticello/Chris Walton Price: $47,990 Specifications: Drive Type: Rear-wheel drive Transmission Type: Six-speed manual Engine Type: V8 Displacement (cc/cu-in): 4,951/302 Redline (rpm): 7,500 Horsepower (hp @ rpm): 444 @ 7,500 Torque (lb-ft @ rpm): 380 @ 4,500 Brake Type (front): 14.0-inch one-piece ventilated cast-iron discs with four-piston fixed calipers Brake Type (rear): 11.8-inch one-piece ventilated cast-iron discs with single-piston sliding calipers Steering System: Electric-assist rack-and-pinion power steering with three driver-selectable modes (Comfort, Normal, Sport) Suspension Type (front): Independent MacPherson struts, coil springs, adjustable five-mode variable dampers, stabilizer bar Suspension Type (rear): Solid axle, coil springs, adjustable five-mode variable dampers, stabilizer bar Tire Size (front): 255/40ZR19 Z Tire Size (rear): 285/35ZR19 Z Tire Brand: Pirelli Tire Model: P Zero Corsa Tire Type: Summer Wheel Size 19-by-9 inches front -- 19-by-10 inches rear Wheel Material (front/rear): Aluminum As Tested Curb Weight (lb): 3,620 Test Results: Acceleration 0 - 30 (sec): 1.9 0 - 45 (sec): 3.3 0 - 60 (sec): 4.6 0 - 75 (sec): 6.4 1/4 Mile (sec @ mph): 12.7 @ 112.9 0 - 60 with 1-ft Rollout (sec): 4.3 Braking 30 - 0 (ft): 26 60 - 0 (ft): 105 Handling Slalom (mph): 70.4 Skid Pad Lateral Acceleration (g): 0.99 Sound Db @ Idle: 54.9 (standard key), 58.8 (TracKey) Db @ Full Throttle: 84.8 (both keys) Db @ 70 mph Cruise: 69.7 (standard key), 70.1 (TracKey) Link:http://blogs.insideline.com/straight...guna-seca.html |
#2 |
Besides the handling, that was a... disappointing read. Maybe this is an example of terrible driving? Meh, only more car rags will tell.
#3 |
![]() ![]() ![]() ![]() Drives: '12 Camaro ZL1 #1255 Join Date: Feb 2007
^^ i have to agree. maby this is car is better on the track than it is on paper.
i mean the camaro ss, is just a little bit slower in alot of those test. and a nice set of coilovers will make the ss run with the boss 302. the ss is 20 hp down and 200pounds heavier than the boss that is practicly using r-comp tires... Camaro ss via inside line. the ss is also 10k cheaper. Drivetrain Drive type Rear-wheel drive Engine type V8 Displacement (cc/cu-in) 6,162 cc (376 cu-in) Block/head material Aluminum/aluminum Valvetrain Overhead valve Compression ratio (x:1) 10.7 Redline (rpm) 6,600 Horsepower (hp @ rpm) 426 @ 5,900 Torque (lb-ft @ rpm) 420 @ 4,600 Transmission type 6-speed manual Track Test Results 0-45 mph (sec.) 3.4 0-60 mph (sec.) 5 0-60 with 1 foot of rollout (sec.) 4.7 0-75 mph (sec.) 6.7 1/4-mile (sec. @ mph) 13.0 @ 110.9 Braking, 30-0 mph (ft.) 27 60-0 mph (ft.) 109 Slalom, 6 x 100 ft. (mph) 68.6 Skid pad, 200-ft. diameter (lateral g) 0.88 Dimensions & Capacities Curb weight, mfr. claim (lbs.) 3849 Curb weight, as tested (lbs.) 3857
#4 |
#5 |
Drives: 2003 Cobra Convertible Join Date: Feb 2009
im not sure what the point is of having the redline right at peak power for the boss. Im sure a tune will do wonders for these. Thats most likely why the stock numbers are what they are despite it putting down over 45rwhp more than an LS3 Camaro SS.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Luminadead/01 Dakota/97 F150 4x4 Join Date: Jul 2009
Oh boy, get ready for all the posts proclaiming the Boss is overpriced.......
#7 |
![]() ![]() ![]() ![]() Drives: 2022 SS 1LE Join Date: Nov 2008
Finally someone agrees with me. push the redline back to 8k - 8.2k and a tune would do wonders.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: the 2nd amendment home Join Date: May 2008
try again
-- Benjamin Franklin lib·er·ty /ˈlibərdē/ noun 1. the state of being free within society from oppressive restrictions imposed by authority on one's way of life, behavior, or political views |
#9 |
#10 |
![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Mar 2010
I'm surprise this car is so heavy. The Ford Racing models are quite close to 3000lbs. What's the point of removing the rear seats if it's still so heavy?
#11 |
love. my. car.
hey, any car that rotates the camshaft to give a more aggressive growl with a key is ok in my book! That being said, any car that I can't afford is too expensive. So that also means that the Chevrolet Suburban 4wd edition is too expensive too
All cars should cost under 30k starting so I can afford them!
#12 |
Rice Harvester
Drives: 2014 Bright Yellow 2SS/RS Join Date: May 2008
Sounds like a crappy driver. People are getting those times from stock 5.0's.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2000 Mustang GT Join Date: Jul 2009
my guess would be they needed the driver mod
evan smith is who I want to see drive the thing. |
#14 |
![]() We'll get specific when the cars ship and hit the dyno's.... Mustang's are usually spec'd on the high side by, ohh, 20% ? Thing needs torque, that's for sure ... oh wait, it's a 302... nevermind
| The 2011+ Mustang Thread | GatorBlue371 | General Automotive + Other Cars Discussion | 11874 | 08-23-2011 12:30 PM |
| 2012 Boss 302 burnout | snakekiller | General Automotive + Other Cars Discussion | 45 | 02-27-2011 02:46 PM |
| 2012 BOSS 302S model specs.... | assasinator | General Automotive + Other Cars Discussion | 15 | 12-06-2010 09:21 PM |
| Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
| Car and Driver Drives the ZR-1 at GM's MCR test track | drummerstevey | General Automotive + Other Cars Discussion | 13 | 09-02-2008 06:22 PM |
