Old 12-06-2010, 08:29 PM   #1
assasinator
1 n the head,2 n da chest
assasinator's Avatar
Drives: 2002 cadillac deville
2012 BOSS 302S model specs....
79,000 dollars
The 2012 Mustang Boss 302S, in a nutshell, is a factory-built turnkey race car. Prepped on the line for SCCA and NASA class racing, loaded with Ford Racing Performance Parts, and carrying a price tag of $79,000, you’d better be serious about speed to keep up. What’s more, the production stream will be limited to just 50 units, whereas the Boss 302R is currently without limitation.
2012 Mustang Boss 302 “S” details
Engine
* 5.0L BossR engine
* Engine oil cooler
* FR serialized intake badge
* Boss 302 fuel system
* Upgraded cooling system
Driveline
* 5L Boss 6 speed transmission with stock Boss 302 clutch/flywheel
* Torsen Diff
* 3.73 gears
* FR1 Muffler
Chassis
* Front: coil over struts
* Front lower control arms with extended ball joint and delrin bushing kit
* FR adjustable front swaybar
* Caster/Camber plates
* Rear: coil over shocksTubular lower control arms with spherical bearings
* FR Swaybar
* EPAS with unique Ford Racing calibration
* FIA Spec 6 point roll cage
Electrical
* Lightened FR wiring harness
* AMB Transponder
* Switch plate – Start/ignition, aux switches
Interior
* AIM data aquisition system with GPS
* Recaro HANS Pro Racer seat
* Fire system with 2 nozzles
* Quick release racing steering wheel
* Window net
* Safety system triangle nets
* 6 point racing harness
* Master cut off switch
Exterior
* FR front splitter
* Rear adjustable CF wing
* Unique fiberglass hood with air extractors
* Hood pins
* 18X9.5″ wheels
* Boss 302S graphics package
* F/R tow hooks
Brakes
* Brembo race 4 piston front brake system
* 2 piece 14″ front rotors
* 2 piece 12″ rear rotors
* PFC racing pads
* Brake duct kit
* Stainless steel brake lines
* FR brake booster assembly
* Unique FR ABS calibration
2011GT E85, Kooks 1-7/8", 3" offroad X, 2-7/8" overaxles, Roush mufflers, CobraJet intake, SCJ monoblade throttle body, drew 4.5" CAI, Boss302S exhaust valve springs, Baby CobraJet exhaust cams. 3.73 gears, lightweight 300A. 455rwhp @7800/410rwtq SAE 5000lb roller dynojet
assasinator is offline   Reply With Quote
Old 12-06-2010, 08:29 PM   #2
assasinator
i guess that turnkey SS race car has a competitor.
Old 12-06-2010, 09:00 PM   #3
Entaille
Drives: 2018 Camaro 2SS
the price is well into z06 or gtr money. ford is going a bit crazy with the new 5.0. pretty ambitious, maybe it will perform well enough to justify the tag? I remain skeptical. I think the lower tier boss 302s are great performers per dollar though
Entaille is offline   Reply With Quote
Old 12-06-2010, 09:03 PM   #4
Sawyer
Sawyer's Avatar
Drives: '13 5.0
I wonder if it can keep up with a GT-R.
2013 Mustang GT Black M6
Sawyer is offline   Reply With Quote
Old 12-06-2010, 09:06 PM   #5
Entaille
it better. being limited to 50 produced i think it will sell even if it doesn't :]
Old 12-06-2010, 09:35 PM   #6
THE EVIL TW1N
Drives: 2003 Cobra Convertible
i dont know if its really WORTH that much,but the list of features DOES add up to a lot of money if you do it yourself......
But with only 50 being built.....yawn who cares this is for the people thatll just throw it a garage. You wont see one on the street possibly EVER.
THE EVIL TW1N is offline   Reply With Quote
Old 12-06-2010, 09:39 PM   #7
assasinator
its has a boss302r engine....you better believe its worth it. up to 550hp depending on class. 8200rpms. . it still isnt a caddy though. you can get 559hp with a V. and look better doing it.
Old 12-06-2010, 09:41 PM   #8
THE EVIL TW1N
what do you mean "up to" 550hp?? im out of the loop./
Old 12-06-2010, 09:43 PM   #9
assasinator
the boss 302r is limited to class rules. robert yates was involved with the fr500c effort and got 550hp from those. the 302R is better in every way it can be. it also spins 8200 at shift point.
Old 12-06-2010, 10:00 PM   #10
assasinator
The engine in the FR500GT we drove is essentially a Roush-Yates engine from a Grand American Rolex Sports Car Series Daytona Prototype and actually is down 16 horsepower from the 550-hp engine Davis wants for production Man Racers. The $12,000 transmission is a six-speed sequential Hollinger unit used in the Australian Touring Car Series. It works like a motorcycle transmission: Pull the lever rearward for upshifts, press forward to downshift. The clutch isn’t needed to upshift, but you need to lift the throttle. Davis says the unit in the production cars should be capable of foot-to-the-floor shifting. (The Boy Racer, incidentally, uses a conventional six-speed Tremec manual.
http://www.bossmustangperformance.co...s-302-mustang/
old roush yates prototype fr500 block
http://www.roushyatesparts.com/Alumi...m-6010-t50.htm
http://www.automobilebox.com/2009/12...ang-boss-302r/
Old 12-06-2010, 10:01 PM   #11
assasinator
there is more power in this coyote than anyone realizes. the coyote isnt just ANY old engine that happened down the road. its a race engine for the street.
“In keeping with the spirit of the original, the new Boss 302 engine achieves its maximum power output at speeds at or above 7,500 rpm,” says Harrison. “Unlike the original engine, however, low-speed torque and driveability are uncompromised thanks to twin independent variable camshaft timing (Ti-VCT) technology and computer-aided engineering design tools.”
Old 12-06-2010, 10:05 PM   #12
a_Username
a_Username's Avatar
Drives: 2010 2SS Camaro
What kinda tires this thing come with? SSX looks better.
Old 12-06-2010, 10:08 PM   #13
assasinator
the SSX does look better.
sorry, the tires arent listed. i guess you can use whatever you prefer on the track.
Borrowing from the Ford Daytona Prototype engines, the resulting short-runners-in-the-box design virtually eliminates lag when the throttle is snapped open while producing peak power output at high rpm.
“The effect of the new intake design is dramatic,” says Harrison. “When I took the prototype car to Mustang Chief Engineer Dave Pericak, he took a short drive, tossed me the keys and said ‘Book it…it’s in the program.’ He knew what we were onto, and that’s really the point where the Boss 302 was born.”
im getting that intake no matter how much it is.
Old 12-06-2010, 10:14 PM   #14
a_Username
a_Username's Avatar
Pirelli PZero summer tires; front:
255/40ZR-19, rear: 285/35ZR-19
I thought this was supposed to be a turnkey track car? Seems odd this comes with street tires.
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
New Shelby Mustang revealed as race-only 'R Model' Sizzox General Automotive + Other Cars Discussion 4 01-30-2009 10:12 PM
The Bullitt and The Boss: Two more new Ford Mustangs for 2007 KILLER74Z28 General Automotive + Other Cars Discussion 9 12-13-2006 09:14 AM
Ford Boss 302 TAG UR IT General Automotive + Other Cars Discussion 5 12-09-2006 08:16 AM
