04-19-2024, 12:10 PM | #1 |
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
Best replacement for 1LE DSSV shocks and struts for street use
I'm going to convert my ZLE back from track to street use since I bought a dedicated track car. Like many of you, I love everything about the car except for the ride. Looking for recommendations for replacement shocks and struts. I've read threads about ones at price points from KW to Detroit Speed. Just looking for a few current opinions before purchasing. Thanks in advance.
04-19-2024, 01:22 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Shocks aren't going to help. The DSSVs are excellent.
It's the fact that there isn't a single piece of rubber in the suspension to combat NVH. Everything in the ZLE is metal on metal.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
04-19-2024, 01:57 PM | #3 |
That's 100% untrue. The 1LE shocks and springs are 3x stiffer than a standard ZL1. Swapping them out for aftermarket coil overs would make a HUGE difference.
04-19-2024, 02:02 PM | #4 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Tons of options. Not sure if there's an Ohlins Road and Track kit for the Camaro, but I've heard a lot of good things about them for street use on other cars.
Another option is just sell and buy a regular ZL1. Magride is really good for street use.
04-19-2024, 02:10 PM | #5 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
Fortune Auto 510. The rear spring perch issue can be fixed by getting their Swift springs from what I understand.
#SAVETHEMANUALS
04-19-2024, 02:15 PM | #6 | |
if i was doing a street car not track use id do a kw v3 kit the rest are mostly junk or too track orientated
04-19-2024, 06:23 PM | #7 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
I've seen a few std Camaros without electronic suspension do really well with the different Bilstein options with matching springs. Seems like a great package for not a lot of money that would work really well on street.
Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
04-20-2024, 09:46 AM | #8 |
Sarcasm loading --------
Detroit speed has some coilovers listed for a camaro.
You should call them to see if they would work on a ZLE. A lot of options came up with a google search. Once again - unsure if they will bolt up to a ZLE. https://www.google.com/search?q=coil...t=gws-wiz-serp
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
04-20-2024, 10:32 AM | #9 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
I've considered a new setup as the corner i need is $1700-1800...and it only lasted about 17k miles.
Gonna hafta be very plug n play though |
04-21-2024, 12:44 AM | #10 |
I have full SPL rear suspension and BMR solid motor mounts. Neither of those bother me as far as NVH. It’s the shocks and struts.
04-21-2024, 12:48 AM | #11 |
Yes that’s what I’ve found. Wish they were any other color but yellow. Maybe consider the Bilstiens with Eibach springs but then it would have the Ronald McDonald look.
04-21-2024, 12:52 AM | #12 |
04-21-2024, 12:55 AM | #13 | |
Appreciate all of the replies so far, thanks to all! |
04-21-2024, 01:32 AM | #14 |
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic Join Date: Mar 2019
I'd sell and buy a standard ZL1.
