Old 07-25-2010, 11:02 AM   #1
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
What makes an engine a 'big block'?
I've always wondered this. Is there a certain cut-off in engine displacement where a motor is considered a 'small block' and above a certain size a 'big block'? or is it other factors? curious
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 07-25-2010, 11:09 AM   #2
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
It is not really about engine displacement, it is more accurately a distinction made by bore separation. For example, a Z06 Corvette with a 7 liter 427 CID engine is a small block, while a Chevelle SS with a 396 CID is a big block. As you can see, that wouldn't make any sense if CID were the determining factor for calling it big/small.
Apex Paul is offline   Reply With Quote
Old 07-25-2010, 11:15 AM   #3
superstockcam
Member
superstockcam's Avatar
Drives: 2010 ABM 2SS/RS LS3
Heavier but much stronger,displacement up to 572 cid. larger free flowing heads and all sorts of other advantages in running a big block, now though the all aluminum motors are better IMO.
superstockcam is offline   Reply With Quote
Old 07-25-2010, 11:24 AM   #4
spyderbuddy
Drives: 2010 RS Inferno Orange Metallic
don't know about ford or dodge but,
mouse motors
small block chevy was 262, 265, 283, 302, 305, 327, 350 & 400 cuin
these engines bacically use the same block, they just diff bore and stroke
then you had the w blocks 348 & 409 cuin
rat motors
and then what chevy called big block
396, 402, 427, 454
and then the same block again just bore and stroke
spyderbuddy is offline   Reply With Quote
Old 07-25-2010, 12:57 PM   #5
AZCamaroFan
Camaro6 2016-2018
AZCamaroFan's Avatar
Drives: sometimes
simply put it's the size of the engine block. A 409 and a 283 were completely different engines, with different size blocks. Same for the 327 and 427. The 454 was the last of the 'big blocks' at Chevrolet. The 427 in the current ZO6 Corvette is actually a 'small block'.
Old 07-25-2010, 02:09 PM   #6
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Yup, the block in a big block is bigger than the block in a small block. Sounds obvious, but thats the basis for it.
For example, on Chevy's the bore spacing on a small block is 4.4" while its 4.84" for a big block. The deck height is 9" for a small block vs 9.8" to 10.2" on big blocks. These differences don't sound like much but it means the max displacement for a small block is about 7L while a big block can surpass 10L.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-25-2010, 02:15 PM   #7
Here is my 502 Big Block
Old 07-25-2010, 02:36 PM   #8
Paul Huizenga
Paul Huizenga's Avatar
Drives: 1991 Syclone, 2000 Corvette
Send a message via AIM to Paul Huizenga Send a message via Skype™ to Paul Huizenga
Some engine families never had that distinction - Pontiac corporate engines, for example, were all one block architecture regardless of displacement.
Paul Huizenga is offline   Reply With Quote
Old 07-25-2010, 03:22 PM   #9
AZCamaroFan
Camaro6 2016-2018
Drives: sometimes
yes that's true. i didn't realize that for a long time
first time i saw a 396 under a hood i was shocked by the size .
Old 07-25-2010, 03:28 PM   #10
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
What he said x2... It's the physical size of the casting of of metal (ie e block) that holds the pistons and crank and other stuff..
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 07-25-2010, 03:32 PM   #11
topgun1
topgun1's Avatar
NICE!!
Old 07-25-2010, 03:33 PM   #12
topgun1
topgun1's Avatar
I love the 454 engine. If I ever get a 69 chevelle SS, I want that engine in it!
thanks for all the info to all, but still....what are the actual specifications that make a block a "big block"? is it a very blurry line or a fine line--i.e. certain bore and stroke, certain displacement, liter, etc.
Old 07-25-2010, 03:34 PM   #13
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
Nothing looks better then a big block in an old Camaro, Vette or Chevelle. The easiest way to tell is by the valve covers.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 07-25-2010, 03:36 PM   #14
Silver2SSRS6spd
Prefer to be blown!
Pontiac had small and large journal engines. More info if you check the link below.
http://en.wikipedia.org/wiki/Pontiac_V8_engine
L99 how many cubic inch soonerfanru2 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 01-16-2011 11:00 PM
500 cubic inch V8 into a 1973 Z28 VRMMMM 1st & 2nd Generation Camaros 0 05-23-2010 02:16 AM
Cubic Inch tnspd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 12-29-2009 12:48 PM
What cubic inch BLU BY U Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-24-2009 12:23 AM
