07-05-2010, 12:22 PM | #1 |
Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
Where is the A/C supposed to drain on the ground?
Hello,
Where is the A/C supposed to drain on the ground? in the center of the car? My car has been running in the driveway for about an hour with the A/C on max to test to see if the A/C drains. It's about 95ºF outside. So far al I see is a tiny drop, one drop, under the center of the car near the tranny. Is this the place? should there be more ? Any service bulliten on it we can upload as PDF ?
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128 Northern Massachusetts & Southern New Hampshire Camaro Club http://www.camaro5.com/forums/group.php?groupid=127 The mother of all supercharger questions thread http://www.camaro5.com/forums/showthread.php?t=77958 My 2010 Camaro Review http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442 2010 Transformer Edition Camaro L99 Auto |
07-05-2010, 12:26 PM | #2 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Why are you idling your car in 95 degree heat with the A/C on for an hour?????
Don't do that, I don't care how bad you want to see where the evaporator drains. That's the WORST thing you can do to a car. If you are worried about it take it to the dealer and have them look at it, but don't idle your car for an hour. COMPLETE waste of gas, HUGE emissions, and VERY bad for your catalitic converters. |
07-05-2010, 12:48 PM | #3 |
Drives: 2010 IBM Camaro SS Join Date: Jun 2007
What he said.. and also.. I have never seen my AC drain even after driving home from work and parking in my garage there is never a wet spot under the car. /shrug
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
07-05-2010, 01:06 PM | #4 |
It drains near the center of the car by the transmission, but from what I have read most of the water is directed next to the exhaust so most if not all is evaporated before it has a chance to leak on the ground, I see your in Mass. , with the low humidity there you probably will never see any water at all, where as where I am it is Extremely humid and all I have ever seen is a spot about 6 inches in diameter.
07-05-2010, 01:20 PM | #5 |
Drives: 2010 supercharged LS3 Join Date: Jan 2010
I havne't parked my car for an hour with the A/C on since high school when thats the only place u had to go with ur gf.
07-05-2010, 01:29 PM | #6 | |
Drives: 2016 & 1967 Camaro, 2015 Impala, +1 Join Date: Jul 2009
There have been problems with the drain tube not attached or kinked. Search the threads many posts last year.
HyperBlue Ash Gray Leather 2LT, 6 Cyl. A8, I06 Nav., NPP, Conv. & Lighting Pkg.
Ordered 3/21/16 ...1100 on 3/24/16...2000 on 3/29/16...Built on 4/25/16 Finally received car on 7/28/16 after 130 days (over 4 Months) |
07-05-2010, 01:32 PM | #7 |
Drives: 05/07 Chevy's Join Date: Aug 2009
The A/C drain is directly above the trans in the center of the hump.
07-05-2010, 01:44 PM | #8 |
This was one post...............
Seems this is a problem that needs to be addressed to many of the early cars. There is a large rubber grommet under the car near the area where the shifter would be. The drain hose gets pinched in the grommet portion of the A/C drain. The techs fished out the hose of the pinched grommet and over a gallon of water came out. The techs said it was like a shower under the car. |
07-05-2010, 05:45 PM | #9 | |
Drives: 2010 2SS Bumble Bee Join Date: Jul 2009
No oil/No coolant But to get on topic they have very little or no drain on the ground.
If you are going through hell, keep going."
"Winston Churchill" " |
07-05-2010, 05:58 PM | #10 |
Retired Veteran
Drives: 2010 Camaro SS/RS Join Date: Jul 2009
AC%20Drain[1].pdf
The water will drain from the drivers side top of the hump above the transmission. If the grommet was pinched and blocks the drain, the trans has to be lowered in order to replace the grommet. There is a lot of heat from both the transmission and the exhaust, so some of the water does evaporate. The thing to really look for as mentioned before is the carpet getting wet, also a musty smell from your vents.
2SS/RS A6 IBM/BLACK SR GFX Midnight wheels
Delivered 8-8-09 |
07-05-2010, 08:08 PM | #11 | |
That should answer most questions....
07-05-2010, 08:29 PM | #12 |
(ʘ‿ʘ)
Drives: The one with a roof rack Join Date: Dec 2009
It gets sucked into the Allspark.
07-05-2010, 08:41 PM | #13 |
NEcamaro5
I do get small amounts of water under the car .I have noticed it under the trany area .haven't givin it much thought
07-05-2010, 09:26 PM | #14 |
Capt. Organization!
Drives: Black 2010 2LT/RS Camaro Join Date: Apr 2010
Hey Bee!
Ok, so I have made a habit of turning the fan on high and shutting the A/C off to "dry out" the line a bit just before I get home. Did that with the last car, seemed to be a smart thing to do. I've noticed that sometimes when I do this, I get a little water sputter through the louvers in the center (right center one to be exact). Reading the PDF, it says that some customers "feel moisture coming from the center vent" DOH! I guess I'll keep an eye on my carpets. I don't like the idea of having them dropping the transmission. Second point - when I had the car up on a lift last week, I noticed what I thought was the A/C drain tube. There was a tube that ran down from the engine compartment along the right of center of the car and had a 45deg bend downward and ended with it's opening point downward. Does anyone have any idea what that is?
>>>Rhode Island Chevy Show<<< June 29, 2014 - What better way to get a sig pic!
>>>Pit Girls @ Angry Hams<<< July 2, 2012 - What better way to get a hot girl pic! |
Similar Threads | ||||
Ground effects screw up!! Please Help | ssalter | 5th Gen Camaro SS LS LT General Discussions | 19 | 01-22-2010 07:48 PM |
93-97 Ground effects | Bulldogwinters | 4th Generation Camaros | 0 | 01-09-2010 12:00 AM |
I am my dealer's Guinea Pig + Ground Effects for sale | PewterPhil | Camaro Price | Ordering | Tracking | Dealers Discussions | 2 | 07-18-2009 11:35 AM |
Color of Ground Effects? | 1wildss | Cosmetics and Lighting Modification Discussions | 5 | 06-24-2009 10:37 AM |
