Old 05-26-2010, 12:45 PM   #1
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
k5 4x4 loud pop truck shakes. . .HELP!!!!
Ok I bought a K5 blazer Sat. we know of several things wrong with it and they were simple fixes. we test drove it and no problems other then it stopped horribly (no one has EVER changed the rear drums/shoes). so I drove it home on the way home randomly I'd hear a loud metal on metal clunk/clank and then the truck shakes.
we got it home pulled the rear tires and drums. the rivets were digging into the drums and the left (driver side) shoe adjuster was broken off with a smashed spring and one of the shoes was bent. we were like ok maybe we were hearing the adjuster hanging on the axel. so we installed new shoes and drums. test drove it of course it stops way better but we still have that metal on metal clunk/clank.
so we drain the rear differential and the fluid looks like muddy water. minor metal shavings on the magnet but no metal chunks. the gear and pinion look fine. we put everything back together and filled with lucas heavy duty gear oil. test drove it no pop. so we were like well since the rear gear oil needed changing we changed the front diff. gear oil with the same kind. we did find two metal chunks and located one tooth on the pinion that was missing a piece. put it back together. I then took it for another test drive. I forgot to unlock the front hubs (aftermarket hubs were installed superwinch) and started to back down the drive way. after realizing it I unliked the hubs. I then made a left out of the neighbor hood and it felt like the driveshaft binded and popped. drove home and parked it and started debating what to do. . .
we took it by a mechanic this morning and he test drove it. the first time the metal on metal clunk happened was when he started braking and it came from the front this time. then upon heading back to the shop it happened three times coming from the rear like it has been. he seemed more concerned with the front then the rear. I'm at a loss on what to do. I don't want to take it to a mechanic that is ignoring both myself and my wife (who went to Nascar techincal institute) but we are both at a loss on what the next step is. . .anyone got an idea?
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 05-26-2010, 11:15 PM   #2
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
first step get new front gears, never run broken equipment. check your trans fluid (probably looks about like the diffs) and check front and rear U-joints. U-joints will often make a random popping sound as they are going bad.
Superman09 is offline   Reply With Quote
hear a loud pop after i gave it gas while it was idling Alain 5th Gen Camaro SS LS LT General Discussions 12 04-27-2010 11:42 AM
2007 Silverado Ext. Cab, Z71 4x4, lots of addons wildcatjake Autos For Sale / Wanted 1 04-16-2010 06:37 PM
VERY LOUD POP FROM REAR END My new Camaro 5th Gen Camaro SS LS LT General Discussions 17 09-20-2009 01:23 AM
2008 Nissan Frontier, 4x4, LE Long bed - Loaded Michael_Js Autos For Sale / Wanted 2 08-26-2009 08:38 PM
