Old 04-30-2010, 06:29 AM   #1
Cmicasa the Great XvX
Drives: 07Taho, 11CamaroRS, 12CTSV Coupe
PlayGround BRAWL: C&D Compares SS and GT... Camaro Wins Performace Test... AGAIN
Article:
Whatever, mass is never an asset in a sports coupe, and it’s one of two elements that work to relegate the Camaro to second place in this rematch with the Mustang GT. This SS is 20 pounds lighter than the car we tested last summer, with more break-in miles, and it grumbled through the 0-to-60-mph and 0-to-100-mph sprints a little quicker this time: 4.6 seconds and 10.5 seconds, respectively. The revitalized Mustang was the Camaro’s equal to 60 mph, but once the 6.2-liter pushrod V-8 (426 horses, 420 pound-feet of torque) got all that metal moving past 60 mph, it was a bit quicker than the Ford.
On the other hand, with a 280-pound weight advantage and a shorter (numerically higher) rear end (3.73:1 versus 3.45), the Mustang was quicker in our 30-to-50-mph and 50-to-70-mph top-gear passing exercises, as well as in the 5-to-60 rolling start.
On the road, particularly a mountain road, the Camaro’s mass is magnified by its dimensions. At 190.4 inches, it’s 2.3 inches longer than the Mustang, 1.6 inches wider (at 75.5 inches), with a roofline 1.6 inches lower (54.2), on a wheelbase (112.3) that’s 5.2 inches long*er, and with a track that’s wider, front and rear. In its defense, this is a solid chassis that’s exemplary in terms of stability and inspires confidence as speeds build, confidence augmented by steering that’s nicely weighted, linear, and tactile throughout its range.
http://www.caranddriver.com/reviews/...mparison_tests
TEST RESULTS
http://www.caranddriver.com/var/ezfl...07775a541f.pdf
Cmicasa the Great XvX is offline   Reply With Quote
Old 04-30-2010, 06:36 AM   #2
Finally some one realizes WHY.. the Camaro is heavier. Extra Metal. This comparo does even more for my "DRIVER'S RACE" opinion... It also makes me want a Camaro as a daily driver even more than before.
Question: Have any of U Camaro buyers looked into after-market Carbon Fiber Hood and trunk weight savings??? I'm guessing about 70lbs.
Old 04-30-2010, 07:02 AM   #3
THE EVIL TW1N
Drives: 2003 Cobra Convertible
Originally Posted by Cmicasa the Great XvX View Post
have you been living under a rock? this has been posted multiple times already.
THE EVIL TW1N is offline   Reply With Quote
Old 04-30-2010, 07:05 AM   #4
THE EVIL TW1N
of course it weighs more because of extra metal. I don't think anybody thought it was from extra plastics. c'mon man, common sense.
and I don't think you can get 70 lbs. off from just a hood and trunk, unless those are cast iron or something along those lines.
Old 04-30-2010, 08:01 AM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Interesting gearing here .... Once the Mustangs get modded, they are shifting in to 5th gear going down the 1/4 ..
Camaro: Gear Ratio:1/MPH Per 1000rpm/Max speed in gear
1 3.01 / 7.9 / 52
2 2.07/ 11.6 / 77
3 1.43 / 16.7 / 110
4 1.00/ 23.9 / 157
5 0.84/ 28.5 / 157
6 0.57/ 42/ 157
Mustang: Gear Ratio:1/MPH Per 1000rpm/Max speed in gear
1 3.66/ 5.8/ 40
2 2.43/ 8.7/ 60
3 1.69/ 12.51/ 86
4 1.32/ 16/ 110
5 1.00/ 21.1/ 146
6 0.65/ 32.4/ 146
Crowley is offline   Reply With Quote
Old 04-30-2010, 09:51 AM   #6
naaaaah.. But I heard U were.:(
Old 04-30-2010, 09:56 AM   #7
I Soooooo wanted to call U something... but I promised that I would be good here.
I gotta ask... Are U to suggest that a CAST IRON hood and trunk would only weigh 70lbs?
Old 04-30-2010, 10:14 AM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
What is the weight difference between the stock aluminum hood and the carbon fiber one? Can't be 70 Lbs, can it?
-Mark.
Stingr69 is offline   Reply With Quote
Old 04-30-2010, 01:25 PM   #9
kevin2323
Drives: challenger
-Mark.
it's not that big of a difference......so the OP is probably wrong.
the challenger guys tried that and it wasnt that big of a difference
kevin2323 is offline   Reply With Quote
Old 04-30-2010, 01:26 PM   #10
8cd03gro
Drives: 2005 STi corn fed
I gotta ask.. how STUPID are U to suggest that a CAST IRON hood and truNk would only weigh 70lbs?
Cast iron? What is this a 5 ton camaro?
8cd03gro is offline   Reply With Quote
Old 04-30-2010, 02:03 PM   #11
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
LMAO .. only about 2 tons
Old 04-30-2010, 02:13 PM   #12
8cd03gro
My point is, I very highly doubt the hood is cast iron.
Old 04-30-2010, 02:40 PM   #13
THE EVIL TW1N
picking up on sarcasm isn't one of their virtues.
Old 04-30-2010, 03:09 PM   #14
Mr CLuTcH
Always On Kill!
Mr CLuTcH's Avatar
Drives: S.I.M. SS
I've been living under a rock. But when I crawled from under, I saw the light.
I'm wondering when someone else is going to duplicate Motor Trends "miracle" quarter mile time for they're Mustang GT. Right now,.....SS leads.
S.I.M. SS(L99):
*American Racing Headers (LT)
*Magnaflow cat-back competition exhaust
*K&N typhoon CAI
*Aggressive cam.
*Tune
**Result**: 465rwhp/ 447rwtq. Satisfied.
Mr CLuTcH is offline   Reply With Quote
