04-10-2010, 01:44 PM | #1 |
Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
Factory Voltage Gauge Question.
My camaro's voltage gauge goes down to just over 12v like a tiny hair over. It will stay there for any amount of time like a half hour for example. Then it will move up to about 14v. I don't know if it is 14v because I have to guess.
Anyway I got it to do it and put a voltage meter on it because I don't know how accurate the factory gauge is. The hand helds meter said 12.9 volts. I've seen my factory gauge actually get a little closer to 12v but not under it. It fluctuates. I was thinking maybe the computer controls the charging and that this may be normal. Like it is charging and resting, charging and resting. Have any of you noticed this with your camaro? Take a look at yours before you reply.
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128 Northern Massachusetts & Southern New Hampshire Camaro Club http://www.camaro5.com/forums/group.php?groupid=127 The mother of all supercharger questions thread http://www.camaro5.com/forums/showthread.php?t=77958 My 2010 Camaro Review http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442 2010 Transformer Edition Camaro L99 Auto |
04-10-2010, 03:07 PM | #2 |
Drives: '19 Camaro 2SS, '12 GMC Yukon Join Date: Oct 2009
I've noticed the same thing on my 1LT/RS. No idea why.
04-10-2010, 03:49 PM | #3 |
Charging System
I'm thinking the computer controls the voltage regulator to either give the alternator a rest or to get slightly better gas milage (everything counts).
So, I'm thinking the computer lets the battery drain for a while then kicks in and charges it back up. Just a theory.
04-10-2010, 04:01 PM | #4 |
Drives: 2010 Camaro 1LT/RS Join Date: Mar 2010
Location: NY Baby girl, unda yo hood, checkin yo shit out
Yeah it'll be at 14v on mine sometimes then as low as 12.2. Not really sure why at all either..
2000 Maxima SE (Exhaust, Intake, 75 Shot Nitrous) - SOLD! 2010 Camaro 1LT RS 6MT - DELIVERED! |
04-10-2010, 04:07 PM | #5 |
Moderator
This is a great question. I'd love to have a GM engineer come in here and answer it for us.
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
04-10-2010, 04:20 PM | #6 |
If i remember, in newer cars they are shutting off the alternators to try and gain gas mileage. They are letting the batteries drain more before kicking the alternator back on. My guess long term your battery wont last as long.
04-10-2010, 04:28 PM | #7 | |
I haven't heard of this before, but it would make sense. I'll try to start watching my gauge and see if it does the same thing.
Black 2SS ordered 1/4/2010, received 2/19/2010
04-10-2010, 04:36 PM | #8 |
Drives: Orange 2SS/RS LS3 Join Date: Apr 2010
yep, noticed it on mine too, i thought it maybe had to do with my radar detector, lights, stereo volume or my phone charger so i played around with all of them while parked and while driving and nothing seemed to make a difference so my first theories were dead wrong haha
04-11-2010, 12:45 PM | #9 |
Drives: Former 2010 and 2013 Camaro owner Join Date: Feb 2010
Interesting - i was gonna call my dealer tomorrow as my voltage gauge stays just above 9. Haven't seen it at 12 yet...
04-11-2010, 12:47 PM | #10 |
Drives: 2010 IBM 2SS/RS Join Date: Feb 2010
That definitely isn't right...my guess is the gauge is bad..if your voltage was that low you should have other symptons...
2010 IBM 2SS/RS Camaro (M6) Previous rides: 2003 Twin Turbo Mustang Cobra(900 RWHP) 2004 KB S/C Mustang Cobra(700 RWHP) 2003 Mustang GT,Heads,Cam, N20 ect.. |
04-11-2010, 12:49 PM | #11 |
Drives: 2010 camaro ss Join Date: May 2009
you hit the nail on the head the pcm modulates voltages as needed,why would you need 14.6 volts all the time it makes sense,hell some makes are actually putting clutches on the alt.pulleys,look at new dodges its all about adding hp and lowering emissions
04-11-2010, 01:06 PM | #12 |
From Owner's manual:
Battery Load Management The vehicle has Electric Power Management (EPM) that estimates the battery’s temperature and state of charge. It then adjusts the voltage for best performance and extended life of the battery. When the battery’s state of charge is low, the voltage is raised slightly to quickly bring the charge back up. When the state of charge is high, the voltage is lowered slightly to prevent overcharging. If the vehicle has a voltmeter gage or a voltage display on the Driver Information Center (DIC), you may see the voltage move up or down. This is normal. If there is a problem, an alert will be displayed. The battery can be discharged at idle if the electrical loads are very high. This is true for all vehicles. This is because the generator (alternator) may not be spinning fast enough at idle to produce all the power that is needed for very high electrical loads.A high electrical load occurs when several of the following are on, such as: headlamps, high beams, fog lamps, rear window defogger, climate control fan at high speed, heated seats, engine cooling fans, trailer loads, and loads plugged into accessory power outlets. EPM works to prevent excessive discharge of the battery. It does this by balancing the generator’s output and the vehicle’s electrical needs. It can increase engine idle speed to generate more power, whenever needed. It can temporarily reduce the power demands of some accessories. Normally, these actions occur in steps or levels, without being noticeable. In rare cases at the highest levels of corrective action, this action may be noticeable to the driver. If so, a Driver Information Center (DIC) message might be displayed, such as BATTERY SAVER ACTIVE, BATTERY VOLTAGE LOW, or LOW BATTERY. If one of these messages display, it is recommended that the driver reduce the electrical loads as much as possible. See Driver Information Center (DIC) on page 4-27 |
04-11-2010, 02:06 PM | #13 |
Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
+1, normal, same issue on the new GM trucks,,,see post # 3, similar system to that covered above...
http://www.gm-trucks.com/forums/inde...ator+fluxuates |
04-11-2010, 02:20 PM | #14 | |
Drives: 2016 Camaro 2SS/RS Join Date: Oct 2008
Similar Threads | ||||
My Shifter Review – Factory vs Hurst vs MGW | caverman | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 46 | 02-02-2013 04:03 PM |
Quick racing stripe question. | logan1080 | 5th Gen Camaro SS LS LT General Discussions | 6 | 07-31-2009 02:48 PM |
Another Question on the 4 gauge Pack | mikriman | 5th Gen Camaro SS LS LT General Discussions | 8 | 07-19-2009 09:16 PM |
New item - Auto Meter ecometer fuel mileage gauge - plug and play @ PFYC.com | Redshift | Audio / Visual / Electronics/ Gauges / Nav | 0 | 07-01-2009 08:56 AM |
SECOND GEN WATER TEMP GAUGE INACCURATE | 79ZRAG | 1st & 2nd Generation Camaros | 9 | 05-30-2009 05:13 PM |
