Old 04-09-2010, 11:59 PM   #1
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Air Compressor??
So I'm in the market for an air compressor. I don't really know much about them but from what I've found online I'm looking for at least a 60 gallon tank to run air chisels, grinders etc. Who makes the best air compressors? My dad looked online and found Ingersoll rand, anyone have any experience with them?
What is the difference between single stage and dual stage compressors?
What is 1-phase vs 3-phase? Which is better?
Thanks in advance everybody.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 04-10-2010, 03:06 AM   #2
Big Brunsy
Drives: 2010 supercharged LS3
Well I work in maintenance at a milk processing plant, at which we have 2 - 250hp and 1 - 125hp air compressors. You do NOT want a 3 phase, thats in reference to the motor that runs the compressor, and I'm willing to bet alot of money the electricity supply to your house will not support a 3 phase motor (usually 480 volts). For your use you should be able to use any brand compressor from a local home improvement store (Menard's, Lowe's, Home Depot) and be plenty good. But if you must have the best, then as far as i've seen, everything ingersoll rand makes is high quality.
Edit: Talked to a few guys here at work, and they said Ingersoll Rand isn't as good as they used to be. Seriously, any air compressor should last you at very minimum 3-5years
Big Brunsy is offline   Reply With Quote
Old 04-10-2010, 01:47 PM   #3
Big Brunsy
look around the net and you can find some alright deals. Check these out
Old 04-12-2010, 07:57 PM   #4
springerpete
Orange GM freak
springerpete's Avatar
Drives: 2004 3500HD
I have an Ingersoll-Rand 2 stage compressor that is 220v. I've had it for 7yrs trouble free.
Basic maintenance only done to it. Change oil, drain water, and check air filter periodically.
"My hair's turnin' White, my neck is still Red and my collar is still Blue"
springerpete is offline   Reply With Quote
Old 04-12-2010, 09:02 PM   #5
BigMatt
BigMatt's Avatar
I think that's the same one my dad ordered, It's a 2 stage 1 phase 220v with a 60 gallon tank. Good to know that it has been so trouble free for you
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 05:44 PM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 04:34 PM
