#1 |
Future Camaro Owner
Drives: 2010 Jeep Wrangler Sahara 4dr Join Date: Aug 2006
I recently received a nickel sized chip in the hood of my G8 GT. I'm picking up touch up paint today and plan on taking care of it tomorrow. Thing is...I've never used touch up paint before.
My plan is to wash it, touch it up, then move on to polishing, etc. If it matters, my G8 is "White Hot". Any advice? |
#2 |
![]() ![]() ![]() Drives: 2003 m3, 2000 camaro v6, 2004 s4 Join Date: Jan 2010
I've got no idea
#3 |
Drives: 2010 Chevy Equinox LS Join Date: Aug 2007
i dont think id trust myself with paint for a car
#4 | |
I recently fixed some scratches on my RJT and wow! I'm very impressed I got it that good. Anyhow, to do it right, requires patience. Also the ability to stop at "good enough" Know that you will never get it good enough as the factory finish. If the bare metal is exposed, and you have a bit of rust, you will need to sand it. I recommend using a fiberglass sanding pen. 3m makes a nice one. Then coat it with some primer, and leave it over night! Remember patience? You will need to let your car look like crap for a couple of days. When applying the paint, go very thin, and wait about 10 minutes between coats. I personally gave up on coating my touch up with clear coat, since it has a tendency to darken the paint, and no longer match. Once you have gotten the scratch/chip to your liking or "good enough" leave it again overnight. The following day you can then polish it. I've been very successful with quixx, and meguires scratchx for this. It is recommended that you then leave it alone for 30 days before waxing it. Also if you get the paint blobs, or mess up, having some goof off around helps as this stuff will remove the touch up paint when it is a few days old but not your factory paint. Hope that helps. |
#5 |
Future Camaro Owner
Thanks!
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
if you follow the instructions on the bottle,you should have no problem.it won't be perfect,but pretty close.
#7 |
Future Camaro Owner
There are essentially no instructions on the bottle other than "shake well before applying".
#8 |
![]() ![]() ![]() Drives: 2010 Camaro Join Date: Mar 2010
#9 |
Future Camaro Owner
eh...it's livable for the moment. i'm going to clean her up and hit it again. the paint seemed to thin out quite a bit after a day or so. the spot isn't noticable from far away, but if you get up close and look for it it's easy to spot...along with a few others i touched up at the same time.
#10 |
I bet no one would even notice it unless you pointed it out... but then again its the whole fact that YOU know about it.
#11 |
| Paint your own stripes? | blackZbandit | Cosmetics and Lighting Modification Discussions | 44 | 09-18-2011 09:22 AM |
| Adam's Polish & Car care Products | Charlie@STILLEN | Wash/Wax/Detailing and Cosmetic Maintenance Parts | 50 | 04-01-2010 03:28 PM |
| All About the Clay Bar Process | Junkman2008 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 0 | 01-11-2010 10:22 AM |
| Paint your mufflers! | KJS | Cosmetics and Lighting Modification Discussions | 43 | 07-19-2009 08:20 PM |
| Help! Need advice on paint chip on roof of new Camaro. | Mcbug | Camaro Price | Ordering | Tracking | Dealers Discussions | 5 | 06-24-2009 08:29 AM |
