Old 03-17-2010, 02:55 PM   #1
4MULA1
4MULA1's Avatar
Drives: 2SS/RS LS3 6MN ABM
New Member Saying "Hello!"
I'm new as of today and my primary reason for joining is to thank the suppliers that made all the parts I recently put on my SS. Here is a list:
BMR Fabrication - I installed their non-adjustable toe rods, trailing arms, subframe connectors and driveshaft tunnel brace. The parts are top quality, the directions are excellent and I could feel the improvements. It dialed out most of the wheel hop by installing these parts and I am looking at a couple of other items that would eliminate it completely. Their sales/tech people are very friendly and knowledgeable and overall, I had a great experience selecting, buying and installing their parts. I would recommend them to anyone.
MTI Racing - I bought and installed their Six Shooter shifter and it may be my favorite upgrade to the car. If you've ever worked the bolt on a fine rifle then you know how this shifter feels. It's a bit of a pain to install but if you follow the directions to the letter it can be accomplished (like I did it) with jack stands and basic hand tools. It is far superior to the Hurst kit in that all the critical bushings are replaced/upgraded and you have a variety of shift knobs to choose from (including stock). I chose the Blackhawk knob and I already love it. The shift lever itself is almost to pretty to hide with a boot!
I also installed a set of their upgraded spark plug wires and they are also top notch (plus you get to eliminate the stock heat shields for a cleaner look).
Lastly, I ordered their rear spoiler and am currently waiting for it to arrive.
Again, they were helpful, knowledgeable and professional.
Kook's Headers - I ordered a full exhaust system from their man Kool Aid who has probably forgotten more than I will ever know about hot rods. The quality is outstanding and I popped for the Jet Hot coating on the headers which has got to help with temperatures as well as the fact they look great (and will stay that way for a long time with routine cleaning).
The rest of the system is also great looking and easy to install (again, I did it in my own garage with jack stands). It took my buddy and me about 6 hours but we were very anal in our pursuit of perfection. When it was done and we went on the test drive, there was not one squeak, rattle or leak and, although clearances were pretty tight, nothing touched anything it wasn't supposed to.
I used Kook's own mufflers and I can't imagine any other brand sounding any better. It's not obnoxious like the Boy Racers with pineapple juice can mufflers, nor is it raspy like all the 4.6 Mustangs around. It's near stock at idle and in normal driving but from about 3,500 RPM to redline it just sounds...RACECAR! You can almost hear how efficiently your motor is breathing.
Fastlane - This local Houston shop makes what I feel is the best Cold Air Intake around, simply due to the fact that it draws air from down low near the fog light. It's called the Pipeline and it's 4" in diameter with an AEM high quality filter. You must eliminate the stock windshield washer bottle and use their included replacement after swapping over the stock pump and doing a little modification to the hoses.
You need to at least re-flash your PCM after installing (but I knew I would need a tune after the headers anyway) apparently because the relocaton of the MAF sensor.
Here's how easy it was: my wife and I installed it from start to finish in under 2 hours, taking our time.
SLP - I installed their skip-shift eliminator while doing the shifter install only to find out later that it can be turned off by the tuner. So don't waste your money if you're going to have your car professionally tuned.
G-Force - Another local tuning shop with a great reputation, they did the final tune on my car after I had installed all the parts. According to Mike, most LS3 Camaro's have been putting out about 355RWHP and around that sme amount in RWTQ. I didn't have a baseline as I had already installed high performance parts. However, before the tune he put on (my own personal baseline in effect) my car was at 383/383, already a significant improvement. But when I left his shop I was at 405 RWHP and 411 RWTQ.
In conclusion, with all the parts listed above, I have a better riding, better shifting, better sounding and better performing Camaro than before!
Thanks to all the manufacturers and to the Camaro5 fans who, through their blogs, helped me find the parts I wanted.
Kevin
4MULA1 is offline   Reply With Quote
Old 03-17-2010, 02:59 PM   #2
REVOLUTIONSS
REVOLUTIONSS's Avatar
Drives: triple black Super sport
nice write up...... welcome to the 5
[SIGPIC][/SIGPIC]
REVOLUTIONSS is offline   Reply With Quote
Old 03-17-2010, 03:03 PM   #3
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Hello 4MULA1! Haven't seen your Camaro in the Pearland area (yet) but sounds like you've done most of the standard upgrades already. When is the supercharger going on?
rolnslo is offline   Reply With Quote
Old 03-17-2010, 03:53 PM   #4
ron10
Drives: 2010 2SS IOM L99
welcome
Old 03-17-2010, 04:05 PM   #5
viper1cobra
Member Club Elite #131
viper1cobra's Avatar
Drives: 2017 50th Anniversary H50 2SS
Welcome to Camaro5.
viper1cobra is offline   Reply With Quote
Old 03-17-2010, 04:06 PM   #6
Camaro21
Drives: SOLD - 2013 M6 ZL1
Welcome to the Site. Post more pics up when you can !! Nice write up on your progress..
Camaro21 is offline   Reply With Quote
Old 03-17-2010, 04:20 PM   #7
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
welcome!
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 03-17-2010, 04:21 PM   #8
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Old 03-17-2010, 05:16 PM   #9
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
welcome
My build thread.click the pic. COTW 10/24/11
Chris-10 is offline   Reply With Quote
Old 03-17-2010, 06:11 PM   #10
98_Camaro
98_Camaro's Avatar
Drives: 2016 2SS Coupe
Yay! I get to be the first person to use this here!
Haha.
Anyways, sounds like a nice setup! Welcome to the forums.
Gone but not forgotten:
1998 Bright Purple Metallic Camaro
2012 Carbon Flash Metallic 2SS Convertible
2016 Summit White 2SS Coupe M6, NPP, & MRC
Now Driving:
2016 Torch Red Corvette 2LT, NPP, MRC
98_Camaro is offline   Reply With Quote
Old 03-17-2010, 09:48 PM   #11
4MULA1, Welcome to our happy little corner of the net, and to Camaro5. There is a BIG fridge on the back porch with anything you can think of in it...help yourself...of course only take what you can LEGALLY have. Make yourself at home on one of the big fluffy couches, kick your shoes off, put your feet up on one of the tables, yes we are allowed to do that, mom's and wive's here don't care....and take it easy.
Welcome!!
Old 03-17-2010, 10:14 PM   #12
Rickster42
Rickster42's Avatar
Drives: VR Camaro 2SS/RS Auto
Victory Red 2SS/RS Auto Sunroof
Welcome to camaro 5.
Rickster42 is offline   Reply With Quote
Old 03-17-2010, 11:11 PM   #13
shawn18
OWTATIME
shawn18's Avatar
Drives: 1969 CaRaMo
WELCOME!!!
shawn18 is offline   Reply With Quote
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 612 09-06-2024 08:00 AM
Who will be our 1000th Member? TAG UR IT Off-topic Discussions 35 07-20-2011 12:06 PM
CD/DVD clear scratch repair stickers, anyone member them? 2ndgenz28 Off-topic Discussions 9 02-11-2010 04:18 PM
New Member another SS/RS hits the road in NVA Orange Peel 5th Gen Camaro SS LS LT General Discussions 14 06-13-2009 06:47 AM
New Member longtime viewer of the site! pic attached savage99ss 4th Generation Camaros 4 02-10-2009 05:42 PM
