Old 03-15-2010, 08:49 PM   #1
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Car is off, electric fan is still on!
The last two times I've turned off my 2008 HHR SS the electric fan is still going. I've waited about five mins to see if it would shut off. Nope. I had to get back in the car, turn the car back on, then off, then it would shut off.
Bad thermostat?
Thanks Guys!
Old 03-15-2010, 08:53 PM   #2
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Maybe check the relay.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 03-15-2010, 09:01 PM   #3
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
That's what I was thinking? I'll check it out. Thanks!!!
Old 03-15-2010, 09:33 PM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Some fans will run after the car is turned off if it is very hot. Have you ever seen labels under the hood that say "Caution, fan(s) may start at any time."
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein
PAUL SS is offline   Reply With Quote
Old 03-15-2010, 09:50 PM   #5
ron10
Drives: 2010 2SS IOM L99
this is true.
Old 03-15-2010, 09:53 PM   #6
mtcwby
mtcwby's Avatar
That label is because when you have the engine idling and you are under the hood working on something, you are aware of the fan that might not be running at the moment. Most fans are not supposed to run with the key off unless it has been modified to do so.
Old 03-15-2010, 11:54 PM   #7
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The fan in our '97 saturn kept running one day. I was slogging through traffic in the middle of summer, then made a stop just off the highway. It was a worst case scenario for engine heat.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 03-16-2010, 06:30 AM   #8
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
Its normal.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 04-10-2011, 02:44 PM   #9
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Originally Posted by Super83Z View Post
Its normal.
Ok, this same situation happened to me today with my SS. Turned car off. After a minute the fans kicked on, but the car was not running, in fact the key was in my pocket. Waited a bit to see if it would turn off. Nope. So, I started the car up and then turned it off and the fans turned off. This is normal?
Old 04-10-2011, 02:49 PM   #10
Shu71
Drives: 2011 Camaro RS M6
The fans are contolled by a temp switch and the on and off temp is controlled by the ECM. If the temp is above the programmed fan on temp then the fans can kick on even with the engine off...at least if the ECM allows. Many cars back in the 80's were set up like this. Read your owners manual, it should state if the HHR fans can run even with the engine off.
Shu71 is offline   Reply With Quote
Old 04-10-2011, 02:50 PM   #11
BackinBlackSS/RS
Go Blue!!!!!
This is on my Camaro SS.
Old 04-10-2011, 02:59 PM   #12
The Dark Knight
Batmobile in Disguise
The Dark Knight's Avatar
Drives: 2009 Pontiac G8
My G8 does that...my '96 Accord does that. Only when I was driving hard or its a really hot day. I just walk away. Car turns on fine later.
The Dark Knight is offline   Reply With Quote
Old 04-10-2011, 03:16 PM   #13
BackinBlackSS/RS
Go Blue!!!!!
Ok, thanks guys. I just have never experienced this. It is very hot today and I was running at high revs today.
Old 04-10-2011, 04:02 PM   #14
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
those things help extend a cars life, a fan that runs any time it over temp [key on or off], and even better a oil pump that keeps going after shut down for a bit and also one that primes the engine before it starts.
Gran Turismo 5... No Camaro? 5thGenOwner 5th Gen Camaro SS LS LT General Discussions 111 12-06-2011 10:06 AM
The first 4 months of owning my car - pics / vids included Crowley 5th Gen Camaro SS LS LT General Discussions 19 09-30-2009 01:05 PM
Getting Antsy Doc 5th Gen Camaro SS LS LT General Discussions 26 08-19-2009 11:49 AM
1st Car Show and meeting Al Oppenheiser! scrming 5th Gen Camaro SS LS LT General Discussions 44 08-17-2009 04:46 PM
2010 Chevy Camaro SS Indy 500 Pace Car Drive linkwpc Camaro Photos | Spyshots | Video | Media Gallery 0 05-23-2009 09:47 PM
