Old 03-01-2010, 04:16 PM   #1
Christiancoach
Christiancoach's Avatar
Drives: 2008 Holden Commodore SSV
Minimum HP for 200mph
I am sure I am opening a can of worms, but I wanted to gather some opinions.
I frequent a few online boards and over the years I have come across some rediculous claims of top speeds for cars. Like a Supra with 500 rwhp claiming a top speed of over 200. Oh yea, he also claimed to do it on a weekly basis on public roads.
From a realistic standpoint, what is the minimum HP needed to hit 200MPH?
I am sure it will depend on the weight and drag coefficient of the car. So lets just make the playing field simple. Although weight isn't a big contributing factor for top speed runs, 3000lb car street car with a middle of the road drag coefficeint of around .30 to .33.
Christiancoach is offline   Reply With Quote
Old 03-01-2010, 04:20 PM   #2
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
I would think that the supra you speak of can do it with no problem. If he has the correct gear 500hp should do the trick in that car. IMO!
2010 2-Tone is offline   Reply With Quote
Old 03-01-2010, 04:24 PM   #3
ssump29
LOL at most people here.
ssump29's Avatar
Drives: 2005 GTO,2006 M6, 2007 300 Touring
Yeah, that supra could easily do it. Remember the LS3 Vette can hit about 194, now give it a better gearing and it could hit 200 and thats with only 430hp.
Number 5952. oh yeahhhhhhh
ssump29 is offline   Reply With Quote
Old 03-01-2010, 04:28 PM   #4
Brokinarrow
Brokinarrow's Avatar
Drives: 2012 Honda NC700x
As already said above, the 200 mph claim isn't what should be causing disbelief here. The fact that he CLAIMS to be doing 200 regularly on public roads, THAT is a bunch of BS.
Old 03-01-2010, 05:22 PM   #5
carsismeZ06
Corvette and Camaro lover
carsismeZ06's Avatar
Drives: 2010 Camaro...some day...
0 horspower. All you need is a lot of distance between the plane and the ground.
carsismeZ06 is offline   Reply With Quote
Old 03-01-2010, 06:07 PM   #6
SSRich
SSRich's Avatar
Drives: 1967 camaroSS
all depends on the transmission and rearend
SSRich is offline   Reply With Quote
Old 03-01-2010, 07:49 PM   #7
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
It depends on 3 things:
  • cross sectional area
  • drag co-efficient
  • power to the ground at that particular speed
There is an equation for drag-limited top speed:
Multiply 53.26 by the cubic root of power divided by the product of the drag coefficient and the area. That gives you the top speed for a particular power. Rearranged for power to go 200 mph:
hp=Cd*A*(200/53.26)^3
A super aerodynamic Bonneville racer might only need 100 hp to go 200 mph. On the other hand, a semi would need more than 4000. For normal cars, it will be between about 400 and 550 hp. And these are power numbers at the wheel, at that speed. You can't even use peak wheel hp. Power changes with rpms so while a car may peak at 500 rwhp @6000 rpm, odds are it won't be turning 6000 rpm @200 mph. For example, a manual Camaro SS would be turning 4620 rpm with the stock gearing and tire size. So you will need more peak power then you thought, in the case of the Camaro about 650 rwhp @5900 rpm.
The story of the guy with the supra being able to hit 200 mph with 500 rwhp is plausible, until he claimed to do it regularly on public roads. He wouldn't be able to find good enough conditions (smooth road, of sufficient length, with no traffic or curves) to attempt it weekly.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 03-02-2010, 03:44 PM   #8
Christiancoach
Good information!
Thanks DGthe3!
This wasn't supposed to be about one specific Supra. I have seen the claim in several places. Just wanted to see some math to see how rediculous people were being.
Old 03-02-2010, 04:07 PM   #9
coolman
Guest
Here's your answer in a nut shell. about 650Hp
The Physics of Racing
Part 6: Speed and Horsepower
These articles were written by Brian Beckman (brianbec@microsoft.com) physicist, and member of No Bucks Racing Club. ©Copyright 1991, Brian Beckman
The title of this month's article consists of two words dear to every racer's heart. This month, we do some ``back of the envelope'' calculations to investigate the basic physics of speed and horsepower (the ``back of the envelope'' style of calculating was covered in part 3 of this series).
How much horsepower does it take to go a certain speed? At first blush, a physicist might be tempted to say ``none,'' because he or she remembers Newton's first law, by which an object moving at a constant speed in a straight line continues so moving forever, even to the end of the Universe, unless acted on by an external force. Everyone knows, however, that it is necessary to keep your foot on the gas to keep a car moving at a constant speed. Keeping your foot on the gas means that you are making the engine apply a backward force to the ground, which applies a reaction force forward on the car, to keep the car moving. In fact, we know a few numbers from our car's shop manual. A late model Corvette, for example, has a top speed of about 150 miles per hour and about 240 hp. This means that if you keep your foot all the way down, using up all 240 hp, you can eventually go 150 mph. It takes a while to get there. In this car, you can get to 60 mph in about 6 seconds (if you don't spin the drive wheels), to 100 mph in about 15 seconds, and 150 in about a minute.
All this seems to contradict Newton's first law. What is going on? An automobile moving at constant speed in a straight line on level ground is, in fact, acted on by a number of external forces that tend to slow it down. Without these forces, the car would coast forever as guaranteed by Newton's first law. You must counteract these forces with the engine, which indirectly creates a reaction force that keeps the car going. When the car is going at a constant speed, the net force on the car, that is, the speeding-up forces minus the slowing-down forces, is zero.
The most important external, slowing-down force is air resistance or drag. The second most important force is friction between the tires and the ground, the so-called rolling resistance. Both these forces are called resistance because they always act to oppose the forward motion of the car in whatever direction it is going. Another physical effect that slows a car down is internal friction in the drive train and wheel bearings. Acting internally, these forces cannot slow the car. However, they push backwards on the tires, which push forward on the ground, which pushes back by Newton's third law, slowing the car down. The internal friction forces are opposed by external reaction forces, which act as slight braking forces, slowing the car. So, Newton and the Universe are safe; everything is working as it should.
How big are the resistance forces, and what role does horsepower play? The physics of air resistance is very complex and an area of vigorous research today. Most of this research is done by the aerospace industry, which is technologically very closely related to the automobile industry, especially when it comes to racing. We'll slog through some arithmetic here to come up with a table that shows how much horsepower it takes to sustain speed. Those who don't have the stomach to go through the math can skim the next few paragraphs.
We cannot derive equations for air resistance here. We'll just look them up. My source is Fluid Mechanics, by L. D. Landau and E. M. Lifshitz, two eminent Russian physicists. They give the following approximate formula: The factors in this equation are the following:
coefficient of friction, a factor depending on the shape of a car and determined by experiment; for a late model Corvette it is about 0.30;
frontal area of the car; for a Corvette, it is about 20 square feet;
Greek letter rho, density of air, which we calculate below;
speed of the car.
Let us calculate the density of air using ``back of the envelope'' methods. We know that air is about 79%Nitrogen and 21%Oxygen. We can look up the fact that Nitrogen has a molecular weight of about 28 and Oxygen has a molecular weight of about 32. What is molecular weight? It is the mass (not the weight, despite the name) of 22.4 liters of gas. It is a number of historical convention, just like feet and inches, and doesn't have any real science behind it. So, we figure that air has an average molecular weight of I admit to using a calculator to do this calculation, against the spirit of the ``back of the envelope'' style. So sue me.
We need to convert to pounds of mass per cubic foot so that we can do the force calculations in familiar, if not convenient, units. It is worthwhile to note, as an aside, that a great deal of the difficulty of doing calculations in the physics of racing has to do with the traditional units of feet, miles, and pounds we use. The metric system makes all such calculations vastly simpler. Napoleon Bonaparte wanted to convert the world the metric system (mostly so his own soldiers could do artillery calculations quickly in their heads) but it is still not in common use in America nearly 200 years later!
Again, we look up the conversion factors. My source is Engineering Formulas by Kurt Gieck, but they can be looked up in almost any encyclopedia or dictionary. There are 1000 liters in a cubic meter, which in turn contains 35.51 cubic feet. Also, a pound-mass contains 453.6 grams. These figures give us, for the density of air
This says that a cubic foot of air weighs 8 hundredths of a pound, and so it does! Air is much more massive than it seems, until you are moving quickly through it, that is.
Let's finish off our equation for air resistance. We want to fill in all the numbers except for speed, , using the Corvette as an example car so that we can calculate the force of air resistance for a variety of speeds. We get We want, at the end, to have in miles per hour, but we need in feet per seconds for the calculations to come out right. We recall that there are 22 feet per second for every 15 miles per hour, giving us
Now (this gets confusing, and it wouldn't be if we were using the metric system), a pound mass is a phony unit. A lb-mass is concocted to have a weight of 1 pound under the action of the Earth's gravity. Pounds are a unit of force or weight, not of mass. We want our force of air resistance in pounds of force, so we have to divide by 32.1, numerically equal to the acceleration of Earth's gravity in , to get pounds of force. You just have to know these things. This was a lot of work, but it's over now. We finally get
Let's calculate a few numbers. The following table gives the force of air resistance for a number of interesting speeds:
We can see that the force of air resistance goes up rapidly with speed, until we need over 350 pounds of constant force just to overcome drag at 150 miles per hour. We can now show where horsepower comes in.
Horsepower is a measure of power, which is a technical term in physics. It measures the amount of work that a force does as it acts over time. Work is another technical term in physics. It measures the actual effect of a force in moving an object over a distance. If we move an object one foot by applying a force of one pound, we are said to be doing one foot-pound of work. If it takes us one second to move the object, we have exerted one foot-pound per second of power. A horsepower is 550 foot-pounds per second. It is another one of those historical units that Napoleon hated and that has no reasonable origin in science.
We can expend one horsepower by exerting 550 pounds of force to move an object 1 foot in 1 second, or by exerting 1 pound of force to move an object 550 feet in 1 second, or by exerting 1 pound of force to move an object 1 foot in 0.001818 seconds, and so on. All these actions take the same amount of power. Incidentally, a horsepower happens to be equal also to 745 watts. So, if you burn about 8 light bulbs in your house, someone somewhere is expending at least one horsepower (and probably more like four or five) in electrical forces to keep all that going for you, and you pay for the service at the end of the month!.
All this means that to find out how much horsepower it takes to overcome air resistance at any speed, we need to multiply the force of air resistance by speed (in feet per second, converted from miles per hour), and divide by 550, to convert foot-lb/sec to horsepower. The formula is and we get the following numbers from the formula for a few interesting speeds.
I put 55 mph and 65 mph in this table to show why some people think that the 55 mph national speed limit saves gasoline. It only requires about 7 hp to overcome drag at 55 mph, while it requires almost 12 hp to overcome drag at 65. Fuel consumption is approximately proportional to horsepower expended.
More interesting to the racer is the fact that it takes 145 hp to overcome drag at 150 mph. We know that our Corvette example car has about 240 hp, so about 95 hp must be going into overcoming rolling resistance and the slight braking forces arising from internal friction in the drive train and wheel bearings. Race cars capable of going 200 mph usually have at least 650 hp, about 350 of which goes into overcoming air resistance. It is probably possible to go 200 mph with a car in the 450-500 hp range, but such a car would have very good aerodynamics; expensive, low-friction internal parts; and low rolling resistance tires, which are designed to have the smallest possible contact patch like high performance bicycle tires, and are therefore not good for handling.
coolman is offline   Reply With Quote
Old 03-03-2010, 01:56 AM   #10
5thGenOwner
5thGenOwner's Avatar
Drives: 2010 SS
Still need aerodynamics!
"The terminal velocity of a skydiver in a free-fall position with a semi-closed parachute is about 195 km/h [120 mph].
Higher speeds can be attained if the skydiver pulls in his or her limbs...
In this case, the terminal velocity increases to about 320 km/h [200 mph]"
http://en.wikipedia.org/wiki/Terminal_velocity
5thGenOwner is offline   Reply With Quote
Old 03-03-2010, 02:41 AM   #11
RocketCutlass
Property USMC
RocketCutlass's Avatar
Drives: 95 Caprice 9C1
My automatic 02 Z28 had a hair less then 500. Had the stock rear and it pulled hard up to 171 with out even breaking a sweat. I let out of it cause I was getting scared. It was done on a closed road too just so everyone knows...
RocketCutlass is offline   Reply With Quote
Old 09-25-2010, 11:24 AM   #12
Carnaut
Drives: 71 Camaro
Yeah, (BS) I strongly agree; I was in a friend's 'supra' on a lonely, flat, straight, smooth section of Az freeway and he opened it up to about 135mph (it took a L-OOOOONNNNN-G time to get up that speed with supposedly modified to almost 400hp), and the car felt: heavy, insecure, it rattled loudly, sluggish, & couldn't seem to stay in one lane. Furthermore, why would someone want to go that fast in a Toyota? It is NOT a muscle car nor especially not any kind of 'supercar'. When we got back into my 71 Camaro w/400sb & modified suspension it seemed much more secure, faster, & lighter.
Carnaut is offline   Reply With Quote
Old 09-25-2010, 12:05 PM   #13
LOWDOWN
Downright Upright
Drives: Daily
Wanna tutorial in Physics? Try this site:
http://www.educypedia.be/education/s...physicsfor.htm
LOWDOWN is offline   Reply With Quote
Old 09-25-2010, 12:24 PM   #14
LostInMoscow
Exiled Speed Junkie
LostInMoscow's Avatar
Drives: None
You can get a lot of cars to go 200 MPH like has been said here. However, to get one to go that fast safely and with stability is another story. You need downforce in the right places and a car that is going to be able to handle all the extra stresses, forces and heat that will be generated. You can shred even the best tires real fast at those speeds if the suspension isn't right. Even if you do all the aerodynamics and powered systems correctly, you're butt will be puckering if the car isn't engineered from the start for those kind of speeds.
Look at the huge differences between a Brabus Mercedes and even the AMG Benzes. They put a hell of a lot of modifications on those cars to get them to go fast safely with good stability. There is a reason that the Germans like that 155 MPH governor. It keeps them from having to deal with these types of issues.
LostInMoscow is offline   Reply With Quote
Lowered Minimum order for 15% off Sale Chris@glimmerglass Wash/Wax/Detailing and Cosmetic Maintenance Parts 0 02-26-2010 09:21 PM
Laws Protecting Consumers for Aftermarket Parts strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 01-17-2010 09:31 AM
Minimum size wheel on SS Brembo Brake JEFF2010SSMANUAL Wheels and Tires Talk Sponsored by The Tire Rack 57 10-21-2009 02:04 PM
IMPORTANT Part 1 Warranty Disputes Zeus Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 08-25-2009 12:37 PM
minimum hp gains from gmpp headers/A.I./catback? s.norman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 75 11-16-2008 03:23 PM
