Old 02-15-2010, 11:24 PM   #1
tvfreakazoid
tvfreakazoid's Avatar
Drives: 98 saturn manual
Problems with my Saturn!
I figured I would ask this question since gm did own saturn. I have a 1998 sacturn sc1 (manual w/150k+ miles). This problem has been happening for off and on for about 2yrs or so. On occasions, when i drive around and come to a stop (while my car is idling), my car idles at almost 2k rpms. I know this is not normal. I've asked around but it seems people can't give me sure answer why this is happening. Any ideas?
I also have problems putting it in 1st and 3rd gear. Meaning it won't go into those gears very easily sometimes.
Any help would be great. Thanks.
You must watch when it comes out or else:slice:
tvfreakazoid is offline   Reply With Quote
Old 02-16-2010, 08:31 AM   #2
Brokinarrow
Brokinarrow's Avatar
Drives: 2012 Honda NC700x
I am not mechanically talented in any way, but my best guess is that the car is just old and needs a tune up. As for the manual trans being difficult to shift, that does happen with age I'm fairly sure. A new clutch should help I think
Old 02-16-2010, 01:05 PM   #3
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
The throttle bodies in them carbon up really bad. I would get it taken off and cleaned thoroughly.
THUMPER20X is offline   Reply With Quote
Old 02-16-2010, 02:46 PM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
There is a stepper motor used for idle control. It is either on its way out or has become contaminated with carbon or oil etc. You may have also developed a vacuum leak from a broken vac line or failed gasket etc.
At those idle speeds it WILL be difficult to get into gear as 1st gear is not synchronized nor designed to engage at those engine/trans speeds. It could also be that the pilot bearing is trashed and dragging on the input shaft.
Only way you are gonna know for sure is to have a competent tech diagnose it....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 02-16-2010, 05:02 PM   #5
THUMPER20X
THUMPER20X's Avatar
Good point about the revs vs. synchro speeds. Def possibility.
Old 02-16-2010, 06:06 PM   #6
venice17517
venice17517's Avatar
Drives: 2010 Camaro
My wife's 2000 with m/t had the same problem and it was the IAC motor. Replace it or try cleaning it. Make sure you clean the passage way also.
venice17517 is offline   Reply With Quote
Old 02-17-2010, 04:45 AM   #7
tvfreakazoid
Thanks for the info. I should of also mention this.
Sometimes or most of the time when I have it in 1st and while the clutch is engaged at the same time, I give it some gas and let go while still in 1st and having the clutch still engaged, the car starts to choke (can't think of a better word for it). It sounds like the car is about to die on me. Is that also linked with the IAC motor as well?:(
What is a ball park figure to get that replaced if it needs to be?
Old 02-17-2010, 05:04 AM   #8
Cmicasa the Great XvX
Drives: 07Taho, 11CamaroRS, 12CTSV Coupe
Check MOTOR/TRANNY mounts. Could be broken and allowing "lift" pulling on accelerator cable. Sounds crazy but it happens.:(
Second... LOVE your Avatar. One of my favorite Movies and TV shows (Firefly)... The girl was HOT.. even better in "Sarah Connor Chronicals."
Cmicasa the Great XvX is offline   Reply With Quote
Old 02-17-2010, 06:17 AM   #9
venice17517
Drives: 2010 Camaro
Its easy to do yourself, you will need a #15 tox on a socket to take the IAC out. Make sure you clean the passage you tell by the end of the pintal how dirty it is. Clean it with some gum cutter. The part is somewhere around $25.00 from your local parts store.
Old 02-19-2010, 05:32 AM   #10
tvfreakazoid
I want to thank everyone for your help.
Old 02-19-2010, 05:37 AM   #11
tvfreakazoid
I dont' want to go off subject but only this one time
You have good taste man. Her name is summer glau. Sarah conner chronicles was a great, great show, but unfortunate it didnt get the ratings it needed and so did firefly:(:(. It shows how bad people can't tell a good tv show these days. Plus she was in 4400 which was an ok show. Yea i'm a huge sci fi fan
Old 02-19-2010, 10:14 AM   #12
bigralph
bigralph's Avatar
Drives: 2001 v6 Camaro
Sea foam and a tone up well work for you.
bigralph is offline   Reply With Quote
Old 02-19-2010, 11:14 AM   #13
305pride
305pride's Avatar
Drives: 3.4l 1995 camaro
my car idled too high when i started my car. what i did was replace the tps sensor and the iac valve. it seems to be alright now. have a thread about this but idk if it relates to yours
http://www.camaro5.com/forums/showthread.php?t=64204
just call me alex. they make anti-me PSA's cos im dope lmao
305pride is offline   Reply With Quote
Old 02-19-2010, 11:17 AM   #14
305pride
305pride's Avatar
i paid 50 bux for the iac valve the other day -_- and in the other store it was like 40 something bux, the tps sensor is about 27 bux
Penske Terminates Saturn Discussion, GM Prepares to Kill Brand FenwickHockey65 General Automotive + Other Cars Discussion 34 10-07-2009 08:22 AM
Saturn Will Survive DkknightX General Automotive + Other Cars Discussion 13 05-01-2009 10:54 AM
Saturn just may survive! Silver Streak General Automotive + Other Cars Discussion 4 02-19-2009 09:46 AM
Warning to 2005-2006 Saturn owners Milk 1027 Off-topic Discussions 2 01-28-2009 04:57 PM
GM working on hybrid power plug-in for Saturn Vue KILLER74Z28 General Automotive + Other Cars Discussion 0 11-29-2006 02:40 PM
