Old 02-10-2010, 02:18 PM   #1
Q's 91z28
TX INFERNO SS
Q's 91z28's Avatar
Drives: 1991 Z28
New pics from 9/11
Some new pics being released today from Sept. 11. All I can say is "WOW" these pics are insane.
:flag1:
http://www.dailymail.co.uk/news/worl...-ABC-News.html
Q's 91z28 is offline
Old 02-10-2010, 03:01 PM   #2
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Sad, sad pictures...:(
The comments towards the bottom of the link are priceless though...
Iwantone2 is offline
Old 02-10-2010, 03:24 PM   #3
Gabe
Gabe's Avatar
Drives: '10 Camaro 2SS/'65 Malibu SS
Here's something to think about...
Any of you think it is odd that the building colapsed (imploded) on itself when the building was hit at the top and not the botom. You figure that the damage or collapsing would have only been to the top floors. Usually takes professionals to make buildings implode the way the did.
If you guys want to see a video that will make you guys questions some s**t check out a video called "Loose Change".
NMCVBC - CGM 2SS/RS/BLK/A6
(original order date): 06/27/09
3000 (accepted to production): 08/17/2009 TPW
3300 (scheduled for prod): 08/17/09
3400 (broadcast): 08/18/09
3800 (produced): 08/22/09 A9138699
4200 (shipped): 8/24/09
5000 (at dealer): 09/04/09
6000 (del to cus): 09/04/09
Gabe is offline
Old 02-10-2010, 03:37 PM   #4
Brokinarrow
Brokinarrow's Avatar
Drives: 2012 Honda NC700x
Conspiracy theories, heh. found a VERY good scientific answer to that whole 'melting point of steel is higher than jet fuel can burn' point here: http://answers.yahoo.com/question/in...0010454AAEhMIJ (labeled as best answer).
To sum: yeah, jet fuel doesn't burn at the temperature that steel melts at. but, the burning jet fuel keeps adding heat to the steel. if the steel isn't able to dissipate this heat faster than more heat gets added, the temp of the steel continues to climb even if the temp of the fire remains the same.
I don't think I did that explanation justice with my very limited understanding of physics, so be sure to read the actual thing and form your own opinions off of that, not my horrible summary of it.
Anyway, back on topic, those are some powerful photos there. But I like how they included the pic of the new tower going up towards the end
Brokinarrow is offline
Old 02-10-2010, 03:41 PM   #5
Hemlawk
AwesomeBillDawesonville
Hemlawk's Avatar
Drives: CGM 2SS/RS =)
I didn't realize helicopters were allowed to fly around NYC at that time.
Incredible images.
Hemlawk is offline
Old 02-10-2010, 03:43 PM   #6
Brokinarrow
Incredible images.
Police helicopters. The link states the photos were taken by police photographers, which is probably why the photos hadn't been released yet (evidence).
Old 02-10-2010, 03:47 PM   #7
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Not to mention that the steel didn't even have to melt. If you've ever worked with steel then you would know that as it gets hot it becomes very, very malleable (as with all metals) - basically the steel kept heating and heating and eventually the reinforcements were able to bend, deform, etc - this initiated the upper levels falling, at which point their cumulative impulse (the measure of force as it is delivered over time - i.e. resting a 20 pound weight on a surface has less impulse than dropping it) was able to overcome the reinforcements of the lower levels.
Also - you don't have to bring a structure down from the bottom, its just easier that way.
- Bryon
Xanthos is offline
Old 02-10-2010, 03:51 PM   #8
jleinaweaver
jleinaweaver's Avatar
Drives: 2010 Camaro 2LT RS
I don't find it odd in the least, the force of the floors collapsing could not be supported by the lower floors. Toss in a hot fire that reduced the structural strength of the building steel skeleton.
If you studied professional implosions, you would understand that they cut up the structure before hand. For a building the size of the WTC, that would have to be a pretty extensive operation, one that wouldn't go unnoticed by the thousands that work there.
jleinaweaver is offline
Old 02-10-2010, 03:56 PM   #9
Brokinarrow
- Bryon
^ also good points.
Old 02-10-2010, 04:05 PM   #10
Tal
Drives: Old
A basic engineering assessment of the design of the World Trade Center dispels many of the myths about its collapse. First, the perimeter tube design of the towers protected them from failing upon impact. The outer columns were engineered to stiffen the towers in heavy wind, and they protected the inner core, which held the gravity load. Removal of some of the outer columns alone could not bring the building down. Furthermore, because of the stiffness of the perimeter design, it was impossible for the aircraft impact to topple the building.
However, the building was not able to withstand the intense heat of the jet fuel fire. While it was impossible for the fuel-rich, diffuse-flame fire to burn at a temperature high enough to melt the steel, its quick ignition and intense heat caused the steel to lose at least half its strength and to deform, causing buckling or crippling. This weakening and deformation caused a few floors to fall, while the weight of the stories above them crushed the floors below, initiating a domino collapse.
http://www.tms.org/pubs/journals/jom...agar-0112.html
Tal is offline
Old 02-10-2010, 04:10 PM   #11
BIG_V_SS
BIG_V_SS's Avatar
Drives: 2010 Chevrolet Camaro 1SS/RS
Regardless of why the buildings fell, it is important to remember why it happened and to get those responsible. Many people lost their lives for absolutely no reason!!
"Sailors belong on ships, ships belong at sea. Land is a mere navigational hazard to be fired upon when necessary!!"
BIG_V_SS is offline
Old 02-10-2010, 04:14 PM   #12
BlackSS831
BlackSS831's Avatar
Drives: 2008 Lexus IS350
I remember seeing that happen at work, dropped to my knee's - couldn't believe it actually happened. Hoping my family in NY wasn't in the area.
BlackSS831 is offline
Old 02-10-2010, 04:16 PM   #13
I understand the physics well enough to know not to listen to the nutt jobs out there that subscribe to these conspriacy theories.
I quit explaining crap to them. I'm not gonna argue when someone says 2+2=7 It's pointless.
PQ is offline
Old 02-10-2010, 04:22 PM   #14
Tin foil hats all around.
FenwickHockey65 is offline
9/11 Message via Fbodfather Moose General Automotive + Other Cars Discussion 44 09-11-2008 05:50 PM
Pics of my Vegas trip this weekend (pics of a real nice 60's Camaro) Mindz Camaro Photos | Spyshots | Video | Media Gallery 16 01-17-2008 01:29 AM
