Old 09-27-2025, 01:08 PM   #1
Camaro Kath
Drives: Chevrolet, Camaro
HVAC suddenly shuts off, both sides go hot with a noise in dash
Hello, 2016 Camaro v6. AC on working well then suddenly turns hot on both Drivers and Passenger side with a noise in the dash when this happens. Shortly later and it works well. I have been fighting this issue for years.
New and programmed HVAC controller, new relay, new low/high pressure switch, new thermal expansion valve. No data codes in computer.
Please help.
Camaro Kath is offline   Reply With Quote
Old 09-28-2025, 10:01 AM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Check the refrigerant levels?
GM has acknowledged that the high side port is prone to develop a significant leak due to their rubber ball valve design instead of the normal schrader valve and it's recommended to change it ever couple years if using a oem port or swap to an aftermarket port that uses a schrader valve.
Old 09-28-2025, 02:20 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
And maybe post your problem in here. Your cam5 logon will work in here too, mine does. Good luck.
https://www.camaro6.com/forums/forumdisplay.php?f=257
Old 09-29-2025, 11:00 AM   #4
Camaro Kath
Thanks, low and high pressures are perfect in spec.
Old 09-29-2025, 12:39 PM   #5
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Have you replaced the blend door actuator? Have you ever had mice in the car? If yes, they may have chewed a wire harness.
Mark114 is offline   Reply With Quote
Old 10-14-2025, 04:40 PM   #6
Camaro Kath
No mice, and no I have not replaced the blend door actuator.
Old 10-15-2025, 03:16 PM   #7
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
If it's a loud clicking noise, it's the blend door actuator. Not hard to replace, just hard to get at, most of the time.
2020 Camaro 2SS - Riverside Blue, NPP, Magnetic Ride, Sunroof
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint
CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit
My Camaro Journal
DamonZ28 is offline   Reply With Quote
camaro hvac troubles
