#1 |
![]() Drives: Lt1 Join Date: Dec 2024
Manifold connector replacement? Where to buy ?
I own a 2019 Camaro lt1 rs
Had a family member replace my thermostat, upon removing the manifold cover he broke the white clip on the black connector. He then zip tied it and left it alone, I'm not upset cause I know it can be fixed. My issue is, I have no idea what the connector is called or for. I will attach a video screenshot of the area. It's too cold for me to go and get a picture Can someone please help me ? |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SS-RS Join Date: May 2011
I believe you should be alright. The white clip is usually just the "locking" portion of the connector that holds it in place. As long as the connector is fully seated, it should be alright. I broke mine on my MAF connector looonnngggg time ago, and it's been fine.
#3 |
![]() Drives: Zl1 Join Date: Nov 2017
I have a basically unlimited supply of those connectors. I can send you one and either a) you splice in the whole connector or b) you pull out the broken cpa and put a new one in its place. Either way, if the connecor is locked in, the cpa just makes sure it doesnt go anywhere, but that style connector doesnt need a cpa, they are a tricky one to remove by itself.
