#1 |
Thread Killer
Broken yet accurate gas gauge I’m Stumped
Any of the experience mechanics ever seen that? All of a sudden I cannot fill the tank in my wagon. [1980 Buick Electra Estate Wagon] I can only get a tad above half and its coming out the filler. Though it reads use proper, I let it get down to 1/4 and its a squeeze to get 5gals back in. 22gal tank, all new fuel system. tank, lines, pump, carb.......... Still the original sending unit though and ill drop it to change it, if I have too [when it warms up] but it seems odd, if its broke, it shouldn't be accurate on usage between half n a 1/4 ehy? |
#2 |
![]() ![]() ![]() ![]() Drives: 12 Boss 302 Join Date: Sep 2009
Check the vent hose, it could be kinked, or water could have froze in it. Take a gas can with you and try running the car out of gas. If it actually runs out as if it only had a half tank, it is not the sender. If you get a full tanks worth of driving, it is the sender. Just my guess on a web diagnosis.
The biggest mistakes in life come when you know exactly what you are doing.
#3 |
Drives: car Join Date: May 2008
So basically when it's full (gas coming out of the filler neck) it only reads a little over 1/2 tank, and when you use about 5 gal (which is near 1/4 tank) it drops 1/4 from 1/2 to 1/4 on the gauge. So the sender is trying to work. Since it is a new tank and everything the first thing I'd do is check the sender ground to make sure it is good. There should be a wire (black usually) from the sender to the chassis, if it's not getting a good ground the scale/range the gauge shows will be out of whack.
#4 | |
Thread Killer
Thanks, thats a good lead right there. With all the snow n salt it could not be grounded right. |
#5 |
![]() Drives: Speed Shop owner Join Date: Aug 2009
I have seen this on Chevy Blazers, they have an anti-siphon valve in the event of a rollover, and it gets stuck in the closed, or semi closed position, causing fuel to spill out the filler. I have no idea if your Buick wagon uses something similar, but it may be a place to look
Ed |
| Is Gas Baffle Broken? | mck17 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 9 | 01-27-2010 09:06 PM |
| AeroForce Interceptor Gauge Install | tjd24 | Audio / Visual / Electronics/ Gauges / Nav | 7 | 10-21-2009 08:38 AM |
| SS on gas gauge? | bucklwi1 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 07-02-2009 09:33 PM |
| gas prices. | Congoman775 | General Automotive + Other Cars Discussion | 65 | 05-28-2008 12:20 PM |
