#1 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2LT/RS Join Date: Mar 2015
How do you remove a frog from a gas tank?
So this happened.... My wife Ildi went to fill up her Pathfinder and upon removing the gas cap... a frog was staring at her. She tried to get it out but he was already half way inside the filler neck and the opening. How he got there... I do not know. Long story short... she had someone try and help her to remove it and the frog decided to slide his way into the gas tank. I removed the wheel and wheel liner... I do not see any exposed openings to where or how the frog would've gotten behind the gas filler neck and still be alive and alert to make eye contact with my wife. Make it make sense.... Pics below...
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can. |
#2 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
How the heck did it get in there?
#3 |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
I thought it was going to be a joke when i read the title lol. Sadly may ways to remove it but will probably kill the poor frog. Maybe a bent coat hanger and try and gently pull it out
#4 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
Well if the frog dies in the extraction process at least he'll die high as a kite on gas fumes.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
#5 |
It don’t come easy.
Vacuum?
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
My guess is it was some sort of prank on whoever went to get gas Maybe it was thought the frog would jump out or something...Halloween....teenagers....or kids goofing around.
(Who hasn't put airplane glue on a frog and lit it off when you were a kid??...lol) Anyway, I'd investigate to see whos snickering about it...lol...good luck! |
#7 |
Native Floridian
NO!!! I know a guy who tried to vacuum gas out of a boat. Once the vapors hit the sparks on the vacuum motor it exploded!!! He was blown out of the boat and burned extremely bad!!!
#8 |
Native Floridian
If you can still see the frog. This tool might work. You can buy it at Lowes.
#9 |
waiting at the tree
Get him to eat a bolt then use a magnetic pick up tool. J/K
Force him down he will dissolve...he is as good as dead from the fumes now anyway.
#10 |
SoCal C5 Family Member
Drives: 1996 Z28 SS & 2014 ZL1 Join Date: Apr 2009
I'm sure that you will have to drill out some ribbits.....
Vance Chula -
1996 Camaro Z28 SS #1688 2014 Camaro ZL1 Coupe #1956 |
#11 |
![]() Drives: 2024 ZL1 Join Date: Apr 2023
A match and a catchers mitt?
#12 | |
It don’t come easy.
#13 |
![]() Drives: '22 2SS 1LE M6, '12 Audi Q5 Join Date: Mar 2022
Poor little guy's Frog Soup now. :(
1st - '65 Ford Mustang - Candy Apple Red
2nd - '77 Pontiac Trans Am - Black/Gold 3rd - '79 Pontiac Trans Am - White/Gold 4th - '86 Chevrolet Camaro IROC Z28 - White 5th - '91 Ford Mustang GT M5 convertible - White 6th - '00 Chevrolet Camaro Z28 M6 - Rally Red 7th - '12 MINI Cooper S M6 - Chili Red Last - '22 Chevrolet Camaro 2SS 1LE M6 - Rapid Blue |
#14 |
![]() ![]() ![]() ![]() Drives: 2024 Camaro 2SS CE Convertible Join Date: Jul 2013
How did it get in there in the first place?
