05-08-2024, 09:14 PM | #1 |
Drives: Chevy Camaro ZL1 1LE Join Date: Aug 2023
ZL1 1LE Rear Seat
Hello, I still feel like I am new to this as a 2023 ZL1 1LE owner. I know the rear seat fold-down is not available on my car for weight reasons. I saw videos on how to cut some fabric to gain access to the latch to manually unlatch the seat and fold it down. I tried it, I do not have a Latch. I would appreciate any information about how to just remove the Seat Back-Rest completely. Any other thoughts are appreciated. Thanks!
05-08-2024, 09:19 PM | #2 |
Have you tried the "secondary hole" method on the backside of the rear seat, accessing it from the trunk?
05-08-2024, 09:28 PM | #3 |
I did see videos to cut fabric from the trunk side to gain access to the Latch, then manually unlatch it. I did try that. I cut fabric on the Trunk side where the Latch would be. There is no Latch. I think this is a 1LE thing.
05-09-2024, 04:07 AM | #4 |
Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
Hello there!
Yes, folding down the rear seat on ZL1 1LE is unnecessarily complicated... I've been able to fold it by randomly poking a long metal rod (screwdriver extension bar in my case) through the little flap at the top. I wasn't able to do it with my finger (or was too scared I'd end up cutting myself trying haha) Without completely ripping the back of the seat's fabric, I wasn't able to understand the mechanism, nor was I able to attach some wire to make it easier next time around Geoff |
05-09-2024, 05:57 AM | #5 |
I would just remove the backseat if I owned a ZL1 1LE, its a track package therefore doesn't need the backseat. Sounds like a hassle to keep it installed anyway. Save even more weight with it removed.
05-09-2024, 07:56 AM | #6 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
I've done this numerous times.
In the trunk you can get to the center of the back seat where there's a little piece of cloth covering the latch assembly. I've reached in and used a long socket wrench extender to press on the metal latch assembly and it works. |
05-09-2024, 08:17 AM | #7 |
Drives: 2017 Camaro ZL1 Join Date: Feb 2024
So if the seat is there....and the latch is there, but covered.
Where is the weight savings ??? |
05-09-2024, 11:54 AM | #8 | |
Geoff |
05-09-2024, 02:02 PM | #9 | |
It should be the same, except for the attached strap that is missing on the ZL1 1LE for some weird reason.
05-09-2024, 09:28 PM | #10 |
Drives: 2021 ZLE & 1972 Camaro Join Date: Oct 2021
Don't cut the fabric, it's behind the flap that's below the visible hole. Pull the flap down and prod around in there. You'll feel it. You don't need a tool or anything, although if you have shorter arms you might not be able to reach it.
05-10-2024, 07:07 AM | #11 |
Sarcasm loading --------
I read elsewhere on this forum that the ZLE seat doesnt have the bracing the regular seats have.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
05-10-2024, 08:43 AM | #12 | |
Drives: 2022 ZL1 1LE Join Date: Jan 2021
This video was posted on the forum years ago. Maybe it will help
2022 Red Hot ZL1 1LE
1972 Chevy Nova Sold: 1997 Z28 Camaro 2000 Corvette |
05-11-2024, 07:29 PM | #13 |
Thanks to everyone for commenting. What is interesting, is my 2023 does not have a flap. That was the very first thing I looked for. So I made a cut in the fabric. I would be surprised if they made a design change, but I do not know what else it could be....??? No flap for me! Everything else I have seen says you have to lower the seat back to remove it, which I cannot do... so I am stuck!
