05-03-2024, 06:03 AM | #1 |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
trailering your ZL1...
So, I'll be trailering my ZL1 to Katech for additional work, approx. 230 miles. The only trailer I have access to is an open trailer. Would it be wise or not to get some kind of heavy duty car cover for trip or would that just be a hassle and would the speed cause the cover to possibly damage the paint or anything? We're pulling it behind a GMC Sierra HD Denali Diesel. Thanks
2023 ZL1 Auto - CSP 2" Long Tubes by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port | Griptech 2.3" Upper | ATI Super Damper w/18% 9.45" Lower | TooHigh PSI Port Injection w/875cc Injectors | E85 | Brisk RR14S Plugs | Granatelli Malevolent Coil Packs | Katech Low Profile Billet Valve Covers | Katech Duel Fuel Pump System | MightyMouse Wild 1000HP CC | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | Katech Tuned
05-03-2024, 07:19 AM | #2 |
Drives: 2021 ZL1 1LE with PDR Join Date: Oct 2022
Don't put a cover on it, the wind will eat it and cause it to eat your paint. I tow on an open trailer to the track, no issues. Make sure you have good mudflaps and you'll be fine.
I tow on a GMC 1500 with airbags and extended mudflaps. My only beef is the damn bug splatter. |
05-03-2024, 07:27 AM | #3 |
Drives: ‘23 ZL1-1LE Join Date: Mar 2023
https://mbrmarketing.com/body-shop-s...transport-wrap
This is an option, I’ve also used a heavy duty wide stretch wrap you can buy at Home Depot as well. |
05-03-2024, 07:29 AM | #4 |
bootss & Camfab ! Thanks for the info!!!
