Roto-Fab
Old 04-30-2024, 11:31 AM   #1
Saffir3
BBL-BEE
Saffir3's Avatar
Drives: Bright Yellow SS 1LE
eBay Maximizer Exaust So Quiet?????
I was looking for a cheep straight pipe exaust on ebay and I found one called a maximizer exaust. I also was looking at a corsa cat back and I realized they looked the same. I just said screw it now bad can it bee for $216. After installing it and I expected it to be like the gates of hell opening, but I was shurely disappointed. It was less quiet than my closed valves factory NPP exaust, mabie I am just deaf after running open headers for 2 weeks straight as a daily. it sounds great couse of the x pipe but its just quiet, its like I put factory ss mufflers on. Anyone else have this same problem. Im going to post pictures so yall can see the diffrences. What exaust should i go with at this point, what im thinking is just go full straight pipe. I hear some people say they sound like shit straight piped. Corsa sounds great but burning $2300 dosent sound great. I genuinely do not onow what to do now id appreciate the help!!!
Nuthin' But Bolt On's: eBay 1-7/8" Long Tube Headers, SLP Blackwing Cold Air Intake, Phastek Race Scoop, 3" Maximizer Exhaust + 3" Muffler Delete In-To 4" Chrome Tips, Taylor "409" 10.4MM Wires.
No Thoughts.......Head Empty
Saffir3 is offline   Reply With Quote
Old 04-30-2024, 02:14 PM   #2
DirtyDirt
DirtyDirt's Avatar
Drives: 2013 Camaro ZL1
i had Borla ATAk on my 10 2SS and loved it. Soon as spring rolled around I went with the same on my ZL1. Good growl when you start it, or rev it. No drone at all even at highway speeds
2010 2SS SOLD 10-28-23
Borla ATAK Cat Back System
Airaid Full Cold Air Intake
15% tint
Matte Black Rally Stripe
2016 Camaro SS Black Chrome PVD Wheels
Pedal Commander
2013 ZL1 BOUGHT 10-29-23 With 1950 miles
K&N Full CAI
15% tint
Few cosmetic additions when it comes out of winter hibernation
DirtyDirt is offline   Reply With Quote
Old 04-30-2024, 02:18 PM   #3
DirtyDirt
DirtyDirt's Avatar
On a side note... How do I fix my avatar?
15% tint
Pedal Commander
K&N Full CAI
15% tint
Old 04-30-2024, 02:22 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
What kind of headers are you running; factory, long tubes, short tubes? If you're still running factory that could be why. The factory headers are very restrictive and will quite down most exhaust. A set of long tubes will make it noticeably louder.
Old 04-30-2024, 07:16 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ This, get a set of LT's if you don't already have a set. They will change EVERYTHING sound wise!!! I went through about 8-9 different setups on my Camaro, then decided to buy the Corsa 3 inch ZL1 Sport catback,,,, should have just done that in the very beginning!! Wasted a LOT of money...
Old 04-30-2024, 08:14 PM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Personally I'm a fan of Solo Performance exhaust. I've had mine on for 9 years and couldn't be happier. Other than long tube headers, the only other modification I made was Noweeds diverters for when I want to be obnoxiously loud. Solo is great because it isn't crazy expensive, made in America, has a great classic muscle car sound, and is drone free.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 04-30-2024, 11:24 PM   #7
RupertPupkin
Drives: 2014 Camaro SS 1Le
Send those back. Do muffler mod on your npp mufflers.
That's what I did.
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is online now   Reply With Quote
Old 04-30-2024, 11:41 PM   #8
Saffir3
BBL-BEE
Saffir3's Avatar
I just decided out of spite to unbolt the mufflers and leave them hanging to see what the car would sound straight piped and it sounds wicked, I might just take the mufflers off and get some axle back muffler deletes and bolt them bad boys on, because this sounds crazy.... heres video proof!!!!!
https://youtu.be/SRDM25BkKfM?si=4uVcQ1ox5j9Lt3Tt
Old 05-01-2024, 05:02 AM   #9
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Stock NPP with headers is the best 5th gen setup.
CamaroDreams76 is offline   Reply With Quote
Old 05-01-2024, 05:14 AM   #10
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
im with dreams76 stock NPP with a x pipe, LT, and a cam. It shakes the walls in my house.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 05-01-2024, 12:36 PM   #11
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
Same here. I've had the Solo J'Pipes on my 10 SS L99 for 14 years now.
They are a muffler delete exhaust with absolutely no drone at any RPM
and great muscle car sound.
myold88 is offline   Reply With Quote
Old 05-08-2024, 04:39 AM   #12
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
It might just be that mufflers of that size, might be too quiet for you. I have a Borla Touring catback, and Speed Engineering 1-7/8 headers (with off-road connection pipes). The 2.5" catback, with a non-resonated x-pipe, is loud enough for my taste. Anything smaller for rear mufflers, and I might be considering glasspacks or resonators to be put in the mid pipes.
I'm currently about to get a second x-pipe welded into my mid pipes. I don't think it will change the sound or volume too much; but supposedly, it makes the tone a little deeper, and the volume might get a tiny bit quieter (somehow).
You said you have eBay long tubes, which are usually closer to having 1-3/4" primaries. It's not a huge difference IMO, whereas 2" long tubes would be louder than the typical 1-7/8" long tube piping size. I personally wish I had gotten 2" long tubes, but the fitment and potential "modifications" needed (lots of hammering), kinda put me off from getting them...
Also, you might be interested in customizing your exhaust, in a fashion similar to the Mach Solo catback design; which has an x-pipe mid muffler, to straight pipes. It's probably along the same setup, as having a non-resonated x-pipe in your mid pipes, and running decent fiberglass-packed rear mufflers/axleback. I'm still surprised that the 3" catback is actually too quiet for your taste... Usually, they drone a lot more than 2.5", and are somewhat hard to tame.
TheBrightSide is offline   Reply With Quote
Old 05-08-2024, 08:11 AM   #13
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
If you like your exhaust violent, you might love a set of H.A.R.M race mufflers under the car. Great source of weight reduction as well.
