04-29-2024, 03:01 PM | #1 |
Drives: 2024 2SS vert w/M6 & Dual Mode. Red Join Date: May 2023
6.2 V8 and issues with AFM(Active Fuel Management)
I have a friend who is an A level mechanic at a GMC dealer who sees a lot of warranty (and out of warranty) work coming thru the shop on 6.2 equipped Sierras and Yukons due to significant lifter problems caused by AFM(Active Fuel Management) also known as cylinder deactivation. He asked that I post this because his friend just shelled out $115 (K) large for a Cadillac Blackwing with the LT4 and 10 speed auto. Awesome car.
I don't know the extent of the problem with Camaro6, C7 and C8 Vettes that have auto trannys. Are there preventive measures one can take if they have a AFM vehicle before having to have it torn apart ? Will more frequent oil changes help? I feel fortunate that my manual trans equipped Camaro6 hasn't got it- just Direct Injection. Not rubbing it in, mind you just curious and wishing luck to anyone with AFM. BTW, the Blackwing is available with a 6 speed. |
04-29-2024, 03:08 PM | #2 |
Drives: '16 2SS M6 Join Date: Aug 2019
The issue is the lifters wear and will stick in the collapsed position. You have all the same components in your engine, it's just missing some wiring and the computer is not programmed to actuate it so the manual cars don't see the failures. The easy, pre-failure fix is to turn it off in the computer via HP Tuners, or get a Range device to deactivate it.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
04-29-2024, 03:25 PM | #3 |
Drives: 2017 Camaro 1LT Join Date: Sep 2018
or you can disable it via Trifecta tune
04-29-2024, 03:53 PM | #4 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
I installed a Range device on my car at 1500 miles and it will never be removed unless absolutely necessary for warranty work. The fuel savings are minimal and certainly not worth the risk of lifter failure, imho.
ΜΟΛΩΝ ΛΑΒΕ
04-29-2024, 04:45 PM | #5 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
I have a range plugged in 24/7 and it will only come out after the car gets a real tune. Headers and boltons are in the very near future.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
04-29-2024, 04:48 PM | #6 |
Drives: People crazy with my sexiness Join Date: Jun 2023
4 easy steps to fix this:
Step 1: Remove factory cam and lifter junk with VCM Step 2: Install new cam and lifter set sans VCM Step 3: Throw factory cam and lifter set into trash Step 4: Happy motoring
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
04-29-2024, 05:56 PM | #7 | |
Drives: 2011 GMC Sierra 1500 Join Date: Jun 2022
Direct Injection (compared to Port Injection) is just the location of the fuel injectors. As someone else posted above, you have the same AFM parts (cam and lifters) as an automatic car however the AFM software is not enabled/installed so the deactivation does not occur with the manual.
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine built by Shane Parker Current mileage: 313 |
04-29-2024, 06:02 PM | #8 |
Unfortunately/fortunately?, the LT4’s have the junk but not the brains to make the junk work, so it’s only half junk if you know what I mean.
04-29-2024, 06:32 PM | #9 |
Drives: 2019 2SS Riverside Blue Join Date: Aug 2011
This should be pinned. Although many are aware of the issue, some are not.
04-29-2024, 06:44 PM | #10 | |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
I have had a used 2015 C7 Z51 for about a year with a A8 that was never touched or had the triple flush and it works like a dream. Only thing it has done is the hard shift out of park in super hot weather last summer . Not done it in many months and when the mid 90's come back i will see if it does it again. Just beats me why so many A8's were bad and a few never had a prob. Had three C6's and never a prob with the A6. |
04-29-2024, 07:16 PM | #11 | |
Drives: 2SS M6 Hot Wheels #515 Join Date: May 2020
The same junk, AFM blah blah blah, is in the 5.3L that is in the Silverado I now have. Followed olrocker's 1-4 directions to the T. So at 150K, when it was given to me by my Dad, figured was good time to overhaul the engine and get rid of that junk. Hopefully she goes another 2-300K
Rotofab, Soler 87mm ported TB, Kooks headers / green cats, MSD wires, flex fuel
Stock intake (no porting) and stock NPP exhaust. |
04-29-2024, 09:25 PM | #12 | |
From that information my conjecture is the issue impacts cars used in areas with higher humidity much more severely than drier regions, which would explain why only a smaller but relevant subset of A8 units degrade to the point where the shudder becomes tangible.
04-29-2024, 11:56 PM | #13 |
Long hauler
Here’s a look at post failure, think it was best case failure scenario imo
I didn’t own the car when it happened so it’s all I got
2022 2SS 1LE - Window Sticker - Cold Air Inductions Elite Carbon CAI
2016 1LT v6 - Totaled Happiness: Infinite |
04-30-2024, 12:36 AM | #14 |
That's unfortunate- just 10K miles and a lifter issue.
