04-24-2024, 12:29 AM | #1 |
Drives: 2015 SS, 2006 CTS-V (wrecked...) Join Date: Jul 2017
Cam swap, now low oil pressure…
Damn the luck! Guess I pinched the oring when installing the new oil pump the second time… Looks like I’ll be going back in there to put a new oring on. I only have 15psi at hot idle. Not tuned yet, just initial start up. So maybe 600 rpm, but since I installed a Mellng 10295 and fresh oil, darn should have better than 15psi.
Not looking forward to ripping it all apart again. |
04-24-2024, 01:06 AM | #2 |
Drives: 2010 Camaro SS manual Join Date: Feb 2022
If you remove the oil pan completely, you can install the pickup tube carfully and not gamble on the O-ring pinching.
To be able to remove oilpan engine still in the car, I cut the small crossmember off and made flanges to it to be bolted back on.
2010 Camaro SS, LS3 + 6spd manual.
1975 Volvo 242, 357SBC + 6 spd manual. 1978 Blazer offroader with LS1, 1-ton axles. |
04-24-2024, 06:27 AM | #3 |
Does your engine have vvt?
04-24-2024, 10:57 AM | #4 |
04-24-2024, 11:42 AM | #5 | |
04-24-2024, 02:09 PM | #6 |
The reason I ask is when I changed my pump the second time I went with the 10295 and my pressure went down to 15 psi. It was because I have an l99 with vvt and it has a high-volume pump and when I went with the 10295 it is a high-pressure standard volume. So, then I changed it out back to a high-volume pump and my pressure was back to normal. I know this probably doesn't help just thought I would through it out there.
04-24-2024, 11:24 PM | #7 |
Appreciate the comments from you all. I hope to have another go at this over the weekend. Fingers crossed a new oring fixes it. If not I’ll probably order another pump and try again.
