04-21-2024, 01:12 PM | #1 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
Need some new rubber!
Hey guys, I think it's time to replace my current tires (Michelin Pilot Super Sports). They don't have a ton of miles on them, but they are over 10 years old. I'm thinking of trying something different since these tires don't provide an amount of traction I'm comfortable with. I'm not sure ANY tire will, but I'm open to suggestions. My current setup is putting down about 600 rwhp.
I don't really go to the track anymore, so just looking for something that will work well for street driving (mostly summer and some rain, but no snow). My current tire sizes are: Front 275/35/20 Rear 295/35/20 Wheels (Forgestar F14) Front 20 x 10 Rear 20 x 11 So, what do y'all think? My main concern is keeping the ass end from breaking loose during "vigorous" starts. Not sure if I can go even wider in the rear with my current rims? I don't care if the tires stick out a bit. Thanks for any advice!!
04-21-2024, 01:15 PM | #2 |
Drives: 2013 ZL1 Join Date: Nov 2018
These, in 80 degree air they dead hook from a 1st gear roll with 600 wheel and turn very very well
https://www.tirerack.com/tires/bfgoo...omp-2-a-s-plus
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
04-21-2024, 04:11 PM | #3 | |
It don’t come easy.
04-21-2024, 05:56 PM | #4 | ||
Thanks, guys. I see they are all seasons (as opposed to summer tires). Does that matter? It sounds like the hook up well, which is really what matters to me
04-21-2024, 05:58 PM | #5 |
P.S. Website is saying they don't come in 295/35 20 =(
04-22-2024, 02:16 AM | #6 |
04-23-2024, 10:08 AM | #7 |
So, I think I'm gonna go up to 315s (from 295) in the back. Wondering if I should keep my current 275 size up front?
Thanks for the tire suggestions! Besides what was mentioned, I've heard good things about the Michelin PS 4S, Firestone Indy 500s, Goodyear G3, and a few others. It's a tough call. A straight up DR is also an option, but I do drive when it's wet occasionally, so those might not be the best idea....
04-24-2024, 08:37 AM | #8 | |
Drives: 2010 Camaro Join Date: Dec 2022
Def do 315 in the back. I run 275 up front as well. As far as tire I recommend Conti ExtremeContact DWS06 Plus. I ran these at 650whp and they performed very well. I'm pretty sure I cut a low 7 60-130mph on these(I can't remember). So they hook well for a street tire and not scary in the rain like a DR. They also last quite a while. I'm actually still running them up front. If you go DR do the MT Street S/S, but if its real wet outside, take another car or pull over with any DR. Hydroplaned a vette on interstate doing a lane change on those once.
2010 SS / 376 LSX / AGP Twin Turbo / 910whp 954wtq
04-24-2024, 09:58 AM | #9 |
Anthony S
I run 315's in the rear and 245s in the front. I tried 275's in the front, but I had rubbing issues with my wheel and tire setup. I run the Continental extreme contact tires and I have a hard time spinning the tires with 530rwhp unless i absolutely dump the clutch. Very grippy tire, easy to balance, and tread life seems really good. I live in Florida so they see plenty of hot roads here.
I buy my tires from Tireagent.com and they have great service and alot of options.
04-24-2024, 12:01 PM | #10 | |
04-24-2024, 12:06 PM | #11 | |
04-24-2024, 01:53 PM | #12 | |
Anthony S
I had the same issue you mentioned, rubbing and cutting of the driver side tire. I switched back to a 245 and never had the issue again. Ashen and I blame it on the chips. Gotta stop eating those damn chips. If i road coursed/ auto-x the car... I would have tried harder to keep the 275 front tire. I just street drive my car, so the narrower tire suits me fine. I might look into buying larger tires in the front, the next time I need new tires. Trying to be very budget conscious right now. Money is tight.
04-24-2024, 01:59 PM | #13 | |
Anthony S
04-24-2024, 04:17 PM | #14 |
Tri-County Camaro SWFL
If you want tires that are going to hook with 600+rwhp in 1st gear you need either the Toyo R888R or a radial.
My car makes a smidge over 800 and I'll blow the tires off as soon as boost hits in 2nd. 1st gear is uselss. I have MP4S on 285. I do think MP4S in 315 would probably be pretty good but not what im looking for. My next rear tire will be the Mickey Street SS in 305.
