04-06-2024, 12:37 PM | #1 |
Drives: 2019 2SS/1LE Shadow Grey Join Date: Nov 2015
1LE trailing arms
I have BMR upper and lower trailing arms to install and see that the bolts tend to be 1 time use. I see the one set that I'll need does anyone know where to get these others in red? Not showing an option to purchase. I believe blue are the other bolts needed.
04-06-2024, 02:14 PM | #2 |
You don't need #9 for trailing arms. And #10 would be only needed for an alignment (camber).
04-06-2024, 02:29 PM | #3 |
The ones you circled red are all the same. This includes the inner mounting bolts of the upper and lower trailing arms that are not shown. You need 8 total of part #11610908.
The nuts are reusable. BOLT,REAR SUSPENSION TRAILING ARM AG, AH, AJ, AK37-67 * (LOWER OUTER)(SINGLE USE)(M12X1.75X70, 66THD)(26.6 OD) List Price: $7.18
04-06-2024, 04:49 PM | #4 |
Drives: Chevrolet Camaro Join Date: Feb 2020
I just went through this as well. Here is my cheat sheet, I did SPL toe rods, upper arms, and BMR upper and lower trailing arms.
RF RearLower Control Arm Inner Bolt - 11610915 LF RearLower Control Arm Inner Bolt - 11610915 RF FrontLower Control Arm Inner Bolt - 11611268 LF FrontLower Control Arm Inner Bolt - 11611268 RF/RR Strut Upper Mounting Bolts (6) - 11548081 RF/LF Strut Lower Mounting Bolts (4) - 11547494 RR Lower Control Arm Outer Bolt - 11547215 LR Lower Control Arm Outer Bolt - 11547215 RR Lower Control Arm Inner Bolt - 11611841 LR Lower Control Arm Inner Bolt - 11611841 RR Upper Control Arm Outer Bolt - 11610908 LR Upper Control Arm Outer Bolt - 11610908 RR Upper Control Arm Inner Bolt - 11610909 LR Upper Control Arm Inner Bolt - 11610909 RR Shock Bolt Lower - 11609598 LR Shock Bolt Lower - 11609598 RR Toe Link Outer Bolt - 11609598 LR Toe Link Outer Bolt - 11609598 RR Toe Link Inner Bolt - 11611276 LR Toe Link Inner Bolt - 11611276 RR Lower SwayBar Link Bolt - 11518630 LR Lower SwayBar Link Bolt - 11518630 RR Shock Bolt Lower - 11609598 LR Shock Bolt Lower - 11609598 LR Cradle Front Bolt - 11547921 RR Cradle Front Bolt - 11547921 RR Cradle Rear Bolt - 11611819 LR Cradle Rear Bolt - 11611819 |
04-06-2024, 05:06 PM | #5 |
Great part number list. Thank you very much for posting.
04-09-2024, 11:18 AM | #6 |
Thanks! Yeah was trying to figure out, my diagram sucked! Thanks everyone!
