dave@hennessey
Old 03-19-2024, 12:40 PM   #1
Crystal_Red_SS
Crystal_Red_SS's Avatar
Drives: 2012 Crystal Red Tintcoat 2SS/RS
Strut spacing
Is this the typical spacing in the strut tower on a 2012 SS? Apparently the strut mounts were bad and discovered after the tires were replaced and the suspension hung a little exposing the deteriorated mounts. threw on some new Koni STRs while the OEM struts were out as they were toast after 12 years and only 9,000 miles.
ADM cold air intake with scoop, Solo Mach XL catback exhaust, custom tune, Stainless Power LT headers, RX catch can in Crystal Red Metallic
Custom Grind Cam 222int 230exh .601"/.608 116*+4, TSP 25% UD Pulley w/ ACC Serpentine Belt, 160* Thermostat, Melling High Pressure Oil Pump,LS3 Conversion,C5R Timing Chain,Amzoil ZROD 10W30,NGK TR6 Spark Plugs, Professional Stage II Cylinder Head Porting Service (360+ CFM), Install by 510 Race Engineering
445 RWHP, 419 ft/lb tq
Crystal_Red_SS is offline   Reply With Quote
