03-14-2024, 08:35 AM | #1 |
Anthony S
Tick performance clutch remote bleeder line
Asking $30 shipped. Somehow I ended up with 2 when doing my clutch job.
03-14-2024, 08:47 AM | #2 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
This is a very very good thing!
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
03-14-2024, 11:16 AM | #3 |
Drives: 2015 ZL1, 2015 Z28 Join Date: Dec 2018
I'll take it!!
03-14-2024, 12:30 PM | #4 |
Anthony S
Sold to Kevin! Thank you sir!
