Old 02-18-2024, 12:43 PM   #1
15SLVSS
Drives: 2015 SS LE/1
DSS driveshaft rubbing the E brake cables
Hey all,
So I just got done doing a bunch of work to the rear of my 2015 SS 1LE. I put Hendrix offset bushings in the diff, Gforce axels, BMR trailing and Toe rods and Bilstiens B6 shocks. The car already had BMR 1.25 drop springs before I started. I then added the DSS drive shaft during reassembly. I noticed it was a very tight fit before I did anything so I removed the rear heat shield as well as the front heat shield. I knew I would need a alignment once the work was complete but didn’t expect it to be that off. Any thoughts on what else I can do before alignment? I’m also going to put 17 in wheels with MT tires on the back at 18 in wheels on the front before the alignment which I fear will make it worse. Any thoughts or ideas would be greatly appreciated.
Thanks
15SLVSS is offline   Reply With Quote
Old 02-19-2024, 06:59 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I have a very similar setup, it takes some "finesse" to bend the e-brake cable brackets towards the outside.
Sent from my Pixel 8 Pro using Tapatalk
larry_g is offline   Reply With Quote
Old 02-19-2024, 08:16 AM   #3
15SLVSS
Thanks Larry
