02-09-2024, 09:29 PM | #1 |
Drives: Camaro 2016 RS Join Date: Jan 2022
Side fender emblem/logo question
Hey fellow Camaro lovers!
Today I was about to replace the stock Camaro emblem at the side fenders and realized that, at least on my Camaro, the emblems are not perfectly level, but skewed with the angle near the tire lower than the other angle. Is this normal, to follow the line in the body that goes all over the side? Or in reality the emblem should be level? |
02-09-2024, 09:46 PM | #2 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
When.I put my 1LE badges on I taped the the bottom of the Camaro badge before removing it then used that line for the 1LE badge. You're right though it is slightly tilted.
02-10-2024, 08:30 AM | #3 |
I leveled my ZL1 and did not follow the body lines
02-10-2024, 09:47 AM | #4 |
Drives: Chevrolet Blazer Join Date: Oct 2021
Thanks for the tip. I haven't gotten around to installing my 1LE emblem but I was thinking I should level it to the ground and not body lines. You confirmed my thoughts.
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
02-10-2024, 11:43 AM | #5 |
I used a small torpedo level and painters tape to get a straight level tape line and then applied the emblems.
02-10-2024, 02:15 PM | #6 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Yes they are slightly angled as to follow the slight rake of the car
02-11-2024, 05:52 PM | #7 |
Do you guys have a picture of what is like with the leveled emblem?
I have a new "CAMARO" emblem from GM ready to be installed but not sure if I should do it level (by using a laser level) or following the body lines like the stock emblem. |
02-11-2024, 10:39 PM | #8 | |
Did you get that, or the new Panther emblem kit (because that one is cheeeep, GM doesn't include anything else with it)?
02-14-2024, 05:07 PM | #9 | |
Just curious, the template starts where the fender has the body line, correct? Do you have photos of how it turned out? |
02-14-2024, 06:06 PM | #10 |
Not the best pic but you get the idea
