Old 02-06-2024, 12:22 PM   #1
Mando895
Mando895's Avatar
Drives: Hyper Blue Metallic 2017 Camaro 2SS
Issue connecting to website on home WiFi
I have tried to access the site recently, and every time I attempt to load anything from Camaro5 or Camaro6, I receive the following message:
Forbidden
You don't have permission to access this resource.
I am unsure how or why this issue occurred. I have tried multiple different browsers, but they all have the same issue (error 403). The only way I can access this site at all is to use my phone and LTE. Any help would be greatly appreciated!
2017 Camaro 2SS Hyper Blue Metallic
8-Speed Auto, Magnetic Ride Control, Borla S-Type Exhaust (NPP), HRE FF10s (Tarmac), Michelin PS4S Tires,
Rotofab CAI, SEMA Grille, Mishimoto Oil Catch Can, StopTech Slotted Rotors, PowerStop Z26 Pads
Also Own:
- 2004 Lexus RX330
Mando895 is offline   Reply With Quote
Old 03-14-2024, 12:17 PM   #2
Slayer
Slayer's Avatar
Drives: 2022 LT1 M6 Satin Steel Metallic
I'm having the same issue when connected to WiFi.
Did you find a solution?
Slayer is offline   Reply With Quote
Old 03-14-2024, 12:56 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Are you using a VPN?
Also corrupt cache or a corrupt cookie could also cause the 403 error.
Old 03-14-2024, 02:08 PM   #4
Slayer
Slayer's Avatar
Currently not using a VPN.
I tried clearing the cache and cookies.
It's happening on multiple devices connected to WiFi with Spectrum.
Old 03-14-2024, 06:27 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Hmm Googling "Error 403 wifi" shows this is actually a common issue with not just one solution as there are a vast many possible issues that can cause the 403 error. One thing I did find is if it's possible, take a device that is having the issue and go somewhere else that offers free wifi like coffee shops, Mcdonalds, Walmart, etc and try it again. If you can connect to the site on their wifi then it's most likely not your device but something wrong with the router.
Old 03-15-2024, 08:46 AM   #6
JamesMyBoy
Drives: 2014 2SS/RS
Are you using a computer (at home) with an Ethernet port? If you can connect with that to your cable modem, it will bypass the router. Then you'll have a clue where the problem is.
That's how I have my devices connected - Phones and iPads use WiFi, computer connected to cable modem via Ethernet. Just my two cents :-)
JamesMyBoy is offline   Reply With Quote
Old 03-21-2024, 01:40 PM   #7
Slayer
Slayer's Avatar
I am no longer receiving the forbidden message and can view the site with WIFI. Thank you for your help.
Old 03-21-2024, 01:57 PM   #8
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Did the wife add camaro5 as a porn site in the adult filter? LOL
FasNuf is offline   Reply With Quote
403, 403 forbidden, forbidden, website issue
