01-19-2024, 11:53 PM | #1 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
Aluminum LT4 Thermostat housing
Does anybody know where to get an Aluminum Housing that takes the LT Thermostat. I'd really like to change out my plastic piece especially since I got spacers for the supercharger. However, damn near everybody has the housing that uses the LS Thermostat, and I already have a Brand new low temp Thermostat for the LT4 stock housing.
01-20-2024, 06:56 AM | #2 |
Having FUN in the SUN...
Here you go... I got mine from DMS. Fit and looks great.
https://dedicatedmotorsports.com/pro...t-engines.html
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
01-20-2024, 07:45 AM | #3 | |
OP: every aftermarket aluminum thermostat housing uses the LS thermostat. Sorry!
01-20-2024, 11:11 AM | #4 | |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
They don't make LT aluminum housing stats because the LT design sucks. That's just really all there is to it. Lol.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
01-20-2024, 12:48 PM | #5 |
Guess that was a better explanation lmao!
01-20-2024, 01:53 PM | #6 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
The T-stat that comes with some of these housings as well as one design from MotoRad can stick closed. I bought my housing stat combo from AMP. The neck for the big hose is machined a bit too small so the factory hose clamp has to be replaced for a screw type so you can get enough clamping force to prevent leaks.
There's another thread on here about t-stat problems with aftermarket necks BTW. I installed mine a week before a HPDE day, drove it several days, and it was OK for the first 2 race sessions. 3rd session after 2 laps into the 3rd session it stuck, then opened when I let off the car and the temp went down, ran another lap and it stuck again. I had brought the original GM with me so I swapped it out and everything was fine. From what I could find on the other thread, the Factory GM LS3 is the stat to use. I havent bought one yet though. If you look at the pick of the bottom of the t-stat in that link, you can see the stat is cupped with what looks to be stand offs formed on it. The other moto-rad design for a 2006 GTO is a flat piece with several holes punched into it. Moto-Rad makes 2 slightly different designs of these t-stats. I didnt try the one with the flat disk with holes in it. |
01-20-2024, 03:58 PM | #7 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
You can get LT4 aluminum thermostat housing for under $100 bucks all day long. Type in LT4 thermostat housing on Google .
01-25-2024, 10:28 PM | #8 | |
Drives: 1985 Oldsmobuick Join Date: Oct 2012
01-26-2024, 11:10 AM | #9 |
All of my explanations are educational and informative! It's just that some are better than others is all.
737 HP/ 779 TQ |
01-26-2024, 12:20 PM | #10 | |
01-26-2024, 12:54 PM | #11 |
2019 COPO #32
427 NA 9.38 142MPH 2018 ZL1-NFG-A10 388CI L8T 9.32 147MPH |
01-26-2024, 01:26 PM | #12 | |
01-26-2024, 02:23 PM | #13 |
Gotcha... I need to open my eyes a bit more!
2019 COPO #32
01-26-2024, 03:33 PM | #14 |
Does anybody know the part number for the factory GM LS3 thermostat? I would like to order one as a spare on hand in case the motorad 180 craps out. Thanks.
