AWE Tuning
Old 01-18-2024, 08:23 PM   #1
Bassment
Drives: 2016 Red Hot 2SS M6
Engine light, Heated Oxygen Sensor (HO2S) high voltage
The diagnostic is:
Code P0158
Heated oxygen sensor (HO2S) 2, bank 2 - high voltage
If I clear the engine light, the next time I run the car it comes back on after about 5 minutes.
I haven't noticed anything weird with the engine or with fuel economy.
Should I just replace the sensor? Is there any other diagnostic I can do?
It's a 2016 Camaro 2SS, 115,000 km
Which part do I need? It's a bit confusing if it's upstream/downstream or what side the sensor is on.
Is this something I need to immediately replace? Or can I drive it for a few more months and replace it when its warmer out? (I'm in Canada)
Bassment is offline   Reply With Quote
Old 01-18-2024, 08:29 PM   #2
Bassment
The part I found is:
GM GENUINE 12643708
It suggests replacing both sensors at once?
Old 01-19-2024, 03:53 PM   #3
easttxss
easttxss's Avatar
Drives: '16 2SS M6
There are 4. 2 before the cats(upstream) and 2 after(downstream). They don't last forever, but for now you can just replace the one that is throwing the code. Bank 2 Sensor 2 is the passenger side, rear sensor. The rear sensors only monitor the cats, they do not contribute to the way the engine runs.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
