Roto-Fab
Old 01-06-2024, 07:30 PM   #1
kerplunk318
Drives: 2010 SS
Cold startup blip after long tube install.
I installed long tubes and high flow cats. Love the sound, but on cold starts it sounds like there is a weird blip, and it's not as crisp as before. It doesn't do this when hot or warm. So far I've verified the plug wires are on good, and changed startup airflow and fueling, but it doesn't seem to make a difference. I've also done a couple rounds of MAF tuning, and it runs excellent except this annoying cold start thing.
Am I being too picky here? I love that snappy, aggressive LS startup that most of these cars have.
https://youtube.com/shorts/93xGZvCwG...UlpF4GT8ZfFZSz
kerplunk318 is offline   Reply With Quote
Old 01-06-2024, 07:50 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I think you're being a bit overly picky, as you said. The only thing I can think of is that the exhaust note/pulses are getting out much quicker due to the "free flow" of the headers and HF cats, where as before you had a bit of restriction, or "back pressure" as it used to be called and the exhaust is somewhat slowed down so it has that smooth transition of the idle circuit, where the headers make it sound like a "blip" as you call it because of the extra free flow, then catches up to the idle circuit. If that all makes sense.
Old 01-07-2024, 09:42 AM   #3
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Honestly, I cant really hear the “blip” you’re talking about. Nonetheless, on colder days mine will actually stumble for a half sec, on initial startup only like you but, I figure it’s just that colder air going across the MAF. Really don’t think you need to be overly concerned.
Old 01-07-2024, 10:08 AM   #4
kerplunk318
Drives: 2010 SS
Good deal, thanks for the replies.
Old 01-07-2024, 11:57 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes sir. And I forgot to mention, my Camaro does that all the time, has ever since I installed the headers in 2012... And then the cam. Just the nature of the "beast"!! lol. No worries and enjoy the new found sound and power..
Old 01-07-2024, 06:14 PM   #6
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
That is just the car giving you the que to smile.
acutron42 is offline   Reply With Quote
Old 01-07-2024, 06:48 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Or WAKE UP neighbors!!!
