01-06-2024, 02:32 PM | #1 |
Door Label pic needed
My 2010 2SS/RS is minus the "tire and loading information sticker" located on the drivers door pillar. I have found aftermarket sellers that will custom make a new label for much less than an OEM label. I would like a picture of the label with the information so I can make a correct version for mine. Just have the WRS package 245/45R20 FRT & 275/40R20 RR. Please blank out your vin number before posting. I really appreciate it!
01-06-2024, 03:14 PM | #2 |
Be careful!! Here is some info on that deal..
https://www.camaro5.com/forums/showthread.php?t=305160
01-07-2024, 09:07 AM | #3 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
It's not magic. It's just ECS's policy not to supply decals to the general public. This may be an agreement between ECS and GM for licensing approval.
Anyway, the tire placard is even LESS than a big deal. You can even buy the decal in various places. GM p/n 19206430. Problem is, the decal comes empty, you have to fill in your own info. I've got a tire placard I'm working on and also the door sticker. I'm working on some stuff now for my own cars in the event something happens to it. Even got the QR code on it which is simply the VIN number in QR code form. Here's a work in progress sample of the door label. The barcode even scans correctly. Still got to tweak it better as I was just going off of guesses on the layout. Almost done minus the tweaks, but it's pretty close right now. And then I can laser print it on the label material and cut it out to the right size on my vinyl plotter. (part of the label obscured for obvious reasons).
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
01-07-2024, 10:38 AM | #4 |
i dont have one either thanks to a wreck with a semi.but i do have brand new1/4 panel,door,mirror,1 wheel and tire and a great paint job that matches perfectly.oh yeah,got out unhurt which was a miracle.i dont care about the sticker,im keeping the car until it cant be fixed.
01-07-2024, 11:52 AM | #5 | |
01-07-2024, 02:15 PM | #6 |
im very happy i wasnt in the wifes honda,he would have rolled right over it...
01-07-2024, 02:31 PM | #7 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
If no one here can help you until I get to the car, I'll take a picture of it for you.
I also happen to have a 2010 2SS/RS
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
01-07-2024, 03:36 PM | #8 |
Older Than Dirt
Here you go. 2010 SS/RS.
