01-06-2024, 09:22 AM | #1 |
Drives: 2020 V6 Auto 3LT RS Join Date: Apr 2019
Cold Weather Brake Screech
Now that it got cold out, for the first couple of minutes the brake screech when I tap on them. Is this normal or ?? thanks
01-06-2024, 03:12 PM | #2 |
“ If the temperature dips below 32°F, it can freeze, causing your brakes to make grinding and squealing noises the next time you start up your car. As your brakes heat up, the ice should melt off the brake pads and rotors, resolving the issue”
