TireRack
Old 12-08-2023, 08:55 AM   #1
dudamota
Drives: CAMARO SS 2013 L99
Kit bi turbo for Camaro SS 2013 L99
Hi, My name is Eduardo and I am from Brasil.
I have an Camaro SS 2013 L99 automatic.
I want to install a bi turbo kit.
Should I MUST convert it to LS3 first ?
Can someone tell me where to find or buy those kits ?
Maybe here ??
1-) GPI – L99 to LS3 Conversion Kit for 2010-2015 Chevrolet Camaro SS
https://gwatneyperformance.com/produ...-kit/#camshaft
2-)Hellion 2010-2015 Chevrolet Camaro SS Twin Turbo System
https://www.hellionturbo.com/product...-turbo-system/
I know I will need remap after all instaled and configured.
Do I need to buy anything else or change other stuff ?
thank you.
dudamota is offline   Reply With Quote
Old 12-08-2023, 08:58 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You might want to ask in this section, FORCED INDUCTION..
https://www.camaro5.com/forums/forumdisplay.php?f=74
Old 12-08-2023, 09:12 AM   #3
SlowLS1
SlowLS1's Avatar
Drives: 2010 Camaro SS , 2011 Colorado LS1
Like 1JEWLDSSRS , post in the other section for the best response.
Instead of bi turbo, search twin turbo.
I also recommend using google with search terms like "camaro5 agp" or "camaro5 hellion" Using camaro5 and some keywords will get you results you are looking for.
SlowLS1 is offline   Reply With Quote
Old 12-08-2023, 09:15 AM   #4
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Yes, you'll need to convert to LS3 and fuel, fuel and more fuel. Most major online Camaro retailers will have everything you need to purchase.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 12-08-2023, 09:16 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ Yes sir. If you use the correct key words in your search, it will refer you to the camaro5 website like SlowLS1 said. Everything I have ever searched for always shows something for camaro5..
Old 12-08-2023, 06:00 PM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Depends on what style you are looking for. All of them do the same but the turbo locations are different.
Hellion is a top mount.
Huron and AGP is mid mount.
STS is rear mount.
You can bolt these kits on but you will run out of fuel FAST. I also wouldn't trust the DOD lifters either
CamaroDreams76 is offline   Reply With Quote
Old 12-11-2023, 05:20 AM   #7
dudamota
Thanks for all the replies
Old 12-11-2023, 11:56 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
You won't have any issues finding good kits. The biggest problem you are likely to run into is companies willing to ship internationally. Let us know how it works out for you.
InFiD3ViL is offline   Reply With Quote
Old 12-12-2023, 05:36 AM   #9
dudamota
So as I understood L99 to LS3 Conversion Kit it's a MUST right ?
Should I also need another fuel pump ?
or it is just 2 itens I mentioned ?
thank you
Old 12-12-2023, 07:31 AM   #10
CamaroDreams76
thank you
If you want the car to make good power a fuel pump is a must. At minimum I would do the ZL1 pump and injectors.
Old 12-12-2023, 07:32 AM   #11
SlowLS1
SlowLS1's Avatar
For sure you will need some type of fuel system.
As for L99->LS3 conversion. It's not required, but would be highly recommended.
