Old 11-13-2023, 03:42 PM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
This is dangerous...
Came across this video and I have to say, I am NOT thrilled about this.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | Gen V Hinson Plug Wire Set | BTR 220 Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR6IX-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
FlukeSS is offline   Reply With Quote
Old 11-14-2023, 05:15 AM   #2
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Discussion already in progress here:
https://www.camaro5.com/forums/showthread.php?t=620938
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
