Roto-Fab
Old 11-09-2023, 07:43 PM   #1
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
SLOW START ISSUE UPDATE, Something you might want to check
Been a victim of slow start issues since 2015 when the car was new.
Troubleshooting steps:
1) New battery- granted it was needed
2) New starter
3) DIY.com grounding strap - Both of them
Finally....
4) New Positive Post to Starter Cable - mine was showing a decent amount of resistance when tested.
a) This one was a bitch, as it is a discontinued part.
b) I had to call dealers in Canada as US had 0 units anywhere in the country.
Car finally locked up, would not start no matter how long I let ot cool off and had to get it towed.
This is what you should check if you have the slow start issue - dealer told me and sent a pic of an aftermarket kill switch spliced into the OEM harness. Check the spliced in wore that runs off to the right in the picture.
For the record, I bought the car New with 441 miles on it (demo car). I have also thought about a kill switch but never got around to it. Besides, if I did, it would be in a place convenient for me to get to.
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
