10-26-2023, 11:04 PM | #1 |
Drives: 2016 Chevy Camaro 1SS Join Date: Sep 2023
Misfiring in Cylinders 1,3,5,7
Hello All, I have had some weird engine activity with my car bogging and misfiring at idle. It’s quite odd the car will bog pretty hard for a second then it will fix it’s self for ab a min before coming back. It also misfired on me a few times on the interstate the other day. I took it to a Tech that I know (not a gm tech anymore atleast used to work there along time ago but still enjoys working on camaros) and he ran my codes and we found that cycljnders 1 3 5 7 are all misfiring. He looked around quite a bit but he could not find anything. He said maybe a leak somewhere or an electrical issue of some sorts. We didn’t have more time to go in-depth but I will say i’m having a problem with some bcm fuses blowing and i’m trying to figure out if this misfiring could be related to the bcm issue or is another problem on its own. My tech also suggested that it could just need a tune to fix it but he finds it’s weird that only one side is doing it.
10-27-2023, 07:00 AM | #2 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Any mods?
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
10-27-2023, 10:20 AM | #3 |
Car has cold air intake and headers that were done about 2 months before the problem started.
10-27-2023, 11:47 AM | #4 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
First thing I'd check are for fouled plugs. While not that likely it's the cause, it's easy enough to investigate.
10-27-2023, 12:10 PM | #5 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Entire cylinder bank? Obviously something on one side of the engine has gone wrong. Check All the wiring from the harness to the coils?
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
10-27-2023, 01:57 PM | #6 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
Heat from the headers has melted plug and/or other wires? Would not be the first time its happened on these cars.
ΜΟΛΩΝ ΛΑΒΕ
10-27-2023, 04:07 PM | #7 |
This. Many of those with headers have had weird electrical problems caused by melted wiiring. The problem area is on the passenger side where the header tubes are close to a wiring bundle.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
10-30-2023, 07:59 AM | #8 |
diagnostic, help me, misfire, misfire engine |
