10-23-2023, 10:04 PM | #1 |
Drives: 2010 chevrolet camaro ss Join Date: Oct 2023
2010 ss limp mode
Allright so I'm new to working on my car so I'm trying to learn things, but anyway I have 2010 ss it's been going into limp mode for over a year I've throwed money and parts on it that buddies or stuff I've read about, and seems like I'm in same position. So I've replaced throttle body, gas pedal, fuel pump, maf, map sensors, plugs and wires and more. I have no codes till goes in limp mode and then got anywhere from 4 to 6 codes (p0651 5v ref) usually always but it's different other times (p0122, p2135,u0109,u0073, p0430) I've had cats removed and put non foulers on oxygen sensors but it was going to limp mode before I did all that. Just bought a diablo sport tuner and car runs alot better but still limp mode. Any help or something to check would be greatly appreciated
10-24-2023, 12:56 AM | #2 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
I was way off, didn't read that you already done all that. sorry about that.
Last edited by Infidel67; 10-24-2023 at 11:03 PM. Reason: Removed for being a dummy |
10-24-2023, 07:47 AM | #3 |
You have a problem that is affecting the 5v reference voltage. This 5v is shared by multiple sensors and that 5v can also show up as a DTC on any of the shared sensors.
10-24-2023, 04:12 PM | #4 |
You need a scanner for this diagnostics, Disconnect all the sensors on the 5v2 reference circuit. Unplug the Accelerator Pedal Position Sensor (APP), the Crankshaft Position Sensor (CKP), the brake booster vacuum sensor, the clutch pedal position sensor (if equipped), and the throttle body. Check for the 5 V reference voltage returning, Then u can plug in one at a time to see if you loose 5 V reference 2. Then u can chase that component/circuit. Also spraying a 5% salt water solutions helps with finding wiring issues. Good luck
10-25-2023, 04:51 PM | #5 |
Appreciate it guys, I'm gonna start messing with it this evening I'll let you know. Thanks again
10-25-2023, 05:25 PM | #6 |
Good luck sir!! Hope is is a simple deal..
5v refrence to circuit, limp mode, p0651 |
