10-21-2023, 08:38 AM | #1 |
High oil pressure
I just recently cammed my 2014 1le, and the oil pressure gauge reads high at idle 70psi.When oil temperature is reading 100+ @ idle it reads around 30 psi. When I rev it past 3k or so it reads 70psi. Is this normal for the readings.
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
10-21-2023, 10:04 AM | #2 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
yes, I believe its around 10 psi per 1000 RPMs. starting at about 30 psi
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
10-21-2023, 04:14 PM | #3 |
Did you install a new hi volume oil pump? If so that sounds about right.
10-21-2023, 09:32 PM | #4 |
Did you do anything to the pump? Sounds a little high but not outrageous. My 10355HV on a cold start with the medium spring puts out about 60psi, 30 when hot.
10-22-2023, 10:02 AM | #5 |
Tri-County Camaro SWFL
I have a high volume pump. Cold starts at idle are around 55/60psi. Warm is low 30s
10-22-2023, 02:14 PM | #6 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
10355 HV here (newly installed ) like 65-70at cold start . 30-33 at idle when hot . Running driven dt 5-40 oil . Loving my new found oil pressure over a regular 10355. Thinking of switching back to ls30 but motor after upgrades seems to run a lot hotter plus running e-85 dt-40 seems to stand up to ethanol a lot better . Started using the slightly heavier oil per recommendation from driven . Explaining my build and running ethanol . Oil temps about 210 when up to operating temp .
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
10-22-2023, 05:35 PM | #7 | |
10-23-2023, 05:08 PM | #8 |
I use Mobil 1 5W30 with the Melling 10295 pump, and my cold starts are right around 65-70, idle after warm up is right around 34-35, cruising at 55 mph she sits right at 53-55 psi.
