10-19-2023, 11:28 AM | #1 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
2024 Battery source for dashcam
I know that Gen5diy sells a radar detector/dashcam harness that plugs in on the right side interior, but it's advertised as an ignition only source. I'd like a battery source for the dashcam. I know I'll need to convert it to 5v. Is there anything behind the rearview mirror I can use or does anyone else have a solution? I've seen the Blackview battery, but don't want to go that way as I'm almost always doing short drives that won't have time to charge the dedicated battery.
10-19-2023, 12:11 PM | #2 |
Drives: 23 2SS 1LE Join Date: Feb 2019
I wired mine to the front fuse box. One switched fuse so its on when the car is on, and one active fuse for when I want to use the parking mode. I can find the exact fuses I used after work if that helps.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
10-19-2023, 12:19 PM | #3 |
Having FUN in the SUN...
You could pull from the cig lighter.... which is switched.
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
10-19-2023, 12:46 PM | #4 | |
I know that is an option and I've done it before with my 2018, but was hoping there was an easier way. |
10-19-2023, 12:48 PM | #5 |
I checked mine and it's only active when in ignition or accessory modes, so no joy there. I'm considering using one of the dome lights which appear to be hot all the time, but not sure if there's any sort of time out on the voltage. The dashcam only pulls 2A so I would hope the wiring would support the small extra load. |
10-19-2023, 11:12 PM | #6 |
Drives: Chev Camaro 1le Join Date: May 2021
I used one of these to power mine. great for parking mode and has a switch.
https://www.amazon.ca/REARMASTER-Uni...0&sr=8-10&th=1 |
10-20-2023, 01:06 AM | #7 |
10-20-2023, 04:03 AM | #8 |
Drives: 2024 ZL1 Join Date: Apr 2023
I use the Black Vue Power Magic Pro. Set to 120 hours, it will record for up to 5 days after you shut the vehicle off. If the battery drops below 12 volts it shuts down.
https://www.blackboxmycar.com/pages/...ower-magic-pro |
10-20-2023, 06:30 AM | #9 | |
10-20-2023, 10:30 AM | #10 |
Hot Camaro
I believe the hardwire kit from Viofo (for their cameras) supports things like low voltage shut off and such and it would support direct wire to an always-on source and do the power conversion. Not sure what camera you're looking to use...
10-20-2023, 10:51 AM | #11 | |
I have a Garmin 67W, but I've ordered the Viofo A139 and it should be here today. I think I'm going to put the A139 in the Camaro and move the Garmin to the Tahoe. I also ordered the Garmin OBD tap. It was more expensive compared to the generic ones, but it has a 24h feature and it's a bit slimmer profile. |
10-20-2023, 11:07 AM | #12 |
Drives: 2021 2SS red-line Camaro Join Date: Jan 2018
I saw a Youtube vid by Lethal Garage a while back that said the On Star required full time power. He tapped into that for adding his home link. Its up by the rear view mirror. Maybe you could find the vid for help.
10-20-2023, 11:36 AM | #13 | |
Thanks for the info, but I think I have it figured out. I'm going to tap the OBD port as there's purpose designed products that have other advantages. |
10-20-2023, 12:31 PM | #14 |
Contact Gen5DIY. They will make a harness that has constant power. Plugs into the same spot as the ignition powered one. They made one up for me.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
dashcam |
